The hardware counter is not working in AUTOSAR OS
liuruowen
Hello:
        When I call the EcuM_GoHalt(), the ECU enters the VLPS mode. Under this condition, after waking up through the IO port interrupt, the AUTOSAR OS hardware timer does not work, and even the interrupt cannot be entered. Check the corresponding register. The current value of the register (CVAL0)is not For counting, what is the cause of this problem?
