The CAN transfer bitrate configured on the S32DS is different from that detected by the CAN tool
shuo41
The CAN transfer bitrate configured on the S32DS is different from that detected by the CAN tool,why?bitrate configured by s32dsbitrate configured by s32dscan tool on pc(through can Analyser)can tool on pc(through can Analyser)
PetrS
share project which shows the issue so we can check.
BR, Petr
PetrS
check if selected protocol clock is really the one you specified (40MHz) within clock config.
BR, Petr
shuo41
It is 40MHZ
PetrS
then check if clock is really configured and system clock running from PLL. Also measure TXD line with scope/analyzer to know real bitrate.
You can also check FlexCAN bit timing registers for values written.
BR, Petr
shuo41
I am testing LIN.When I fill in the baud rate column with 9600, my logic analyzer cannot receive data correctly at 9600.When I fill in the baud rate column with 3700, my logic analyzer correctly receives data at 9600.22.png44.png77.png66.png55.png
PetrS
BR, Petr
shuo41
HI,I Solved the problem. My external clock configuration is incorrect.The external clock is 40MHz, and I have configured it to be 16MHz.Thinks for your help.
shuo41
Its source is PLL, that's right. The bit rate measured by my oscilloscope is incorrect.I test Lin, The baud rate it outputs is also incorrect.11.png
