S32K388 GPIOs safety mechanisms implication Apart from redundancy SM4.REDUNDANT_IO
Sandee_pinninti22
Hello Team
We are planning to use S32K388 in highest ASIL rated project
I am using my GPIOs to enable power supply's and some safety critical circuits,
I understood the suggested safety mechanism in safety manual of S32K (SM4.REDUNDANT_IO )
But unfortunately i can not use redundant pins due to GPIO pin usage limitation
in this regards, is there any other safety mechanism that you can suggested or is it capable/support for GPIO self test during every wakeup and Turn_ON of the ECU
S32K3 FUNCTIONAL-SAFETY-SYSTEM-BASIS
