S32K358: Ethernet Solution
Ajay_k
Hi Team,
We are preparing to commence development on the S32K358 with TJA1101.
Could you kindly verify and inform us if there is an existing Ethernet stack for the specified controller and Phy device
Thanks in advance.
Ajay K R
VaneB
Hi @Ajay_k
You can download the TCPIP stack and example application for S32K3XX platform through S32K3 Reference Software > Automotive SW - S32K3 - Stacks.
In the example codes there is a function named Eth_T_InitPhys() witch is in charge of initialize the ethernet Phy as the TJA1100, TJA1101, TJA1103, DP83848 amount others.
B.R.
Vane
