S32K344 set uart tx pin as gpio
Steven_Cho
I config gpio as UART tx and rx pin mode on .mex file.
But I need control UART tx pin as gpio to send a pulse signal to reset sensor before using UART to send data.
How can I do?
Thank you.
Senlent
Hi@Steven_Cho
You can use the below API to change the PIN mux to GPIO or others.
Steven_Cho
It works, thank you.
