S32K344 UART baudrate Customize
Masaki_Mori
I would like to modify and reuse Uart_Example_S32K344 in workspaceS32DS.3.5.
However, the custom code I modified is displayed in light gray and cannot be changed.
I would like to know how to modify and use these configuration codes.231206_uart_baudrate.png
PetrS
you can select "LPUART_UART_BAUDRATE_CUSTOM" as desired baudrate item.
Then you will be able to modify SBR and OSR values. Custom baudrate value is recalculated.
BR, Petr
Masaki_Mori
I was able to get the UART to 6Mbps. Thank you.
