S32K344 J-Link GDB Server failed: Device name 'S32K344' not recognised
2,829 次查看
TZYlss
HI, I want to download S32K344 program through JLINK debugger, but can not recognize S32K344 .
Is this JLINK firmware version too low, or with s32K344EVB-Q257 voltage mismatch caused? Or some other reason.
2,812 次查看
Robin_Shen
Hi TZYlss,
According to the information in your screenshot, V6.42a is too old. As SploreLcp mentioned you need to update the J-Link software.
You can find the Release notes of J-Link, it will mention which new chips have been supported after the version update.
Robin
4 回复数
241 次查看
gajendrahattimare
how to plug in the newer version j-link in S32DS_3.4
2,813 次查看
Robin_Shen
Hi TZYlss,
Robin
235 次查看
gajendrahattimare
how to plug in the latest version of j-link in S32DS 3.4
2,818 次查看
SploreLcp
Yes.
Why not update to the last version or higher than V7.56c.
