Hi, Due to the shortage of samples, I now want to use S32K312NHT0VPBST for prototype test. I wonder whether the schematic diagram can be designed directly according to S32K344 172PIN? Because S32K344 will be used to make products later. During the design of power supply, I found that these two places are different in the manual. What is the purpose of the blue dotted box? Are S32K312NHT0VPBST and S32K344 compatible on the hardware? Thank you very much!
Solved! Go to Solution.
Hi, if you download
https://www.nxp.com/webapp/Download?colCode=S32K3_HW-DesignPackage
and open following file from unpacked package
..\01 - S32K3 - Hardware Design Guidelines\S32K3xx - Hardware Design Guidelines.pdf
Table 16 describes
Pinout differences between S32K344/42/24/22/14 -172MaxQFP and S32K312-172MaxQFP
Hi, if you download
Table 16 describes
OK,Thank you so much !
