S32K312 GPIO register state whether retained after standby mode
feiyiniu
when in view power management system,in standby mode,the GPIO power supply is not enabled,as following picture shows,can i understood that the GPIO register state will not be retained after standby mode? Thanks!power management system.png
Senlent
Hi@feiyiniu
Yes, after reset or interrupt to exit Standby mode, the GPIO configuration will be reset, but S32K3 has the feature of pad keeping
please take a look at the S32K3XXRM-rev5,the chapter:40.9 Pad keeping
Pad keeping allows you to return to I/O Run mode configuration settings after using I/O during Standby mode. It eliminates I/O reconfiguration in Run mode
feiyiniu
Thanks!
