[S32K144]How to restore the debug interface after it is disabled?
Detective
When using the S32DS software, I accidentally set the debug interface pin to be disabled, and then I cannot enter the debug or download the program through the interface. Is there any way to recover?
Thanks and waiting for your reply!
Senlent
You need to reset your board, try a few more times, it is possible in theory,
If not successful, you can only replace the new MCU.
https://mcuoneclipse.com/2013/06/16/bricking-and-recovering-frdm-kl25z-boards-reset-swd-clock-and-lo...
Senlent
please taka a look at this post, and I already send your a private message with the recovery tools attached..
https://community.nxp.com/t5/S32K/S32K-DEV-board-recovery-tool/m-p/1029574
Detective
@Senlent
I can't connect to the MCU using USB Multilink, I may have disabled all the USB Multilink corresponding pins.
Senlent
Detective
Thank you, I have been using the USB Multilink download program, now the USB Multilink can not be connected, different from their openSDA situation, P&E recovery Utility's USB Multilink option can not recover, it seems that I have to replace the MCU,sad.
