S32K1 GPIO output steady state
alphas
Hello, dear engineers, I would like to know the level status and duration of ordinary GPIO of S32K between OTP program execution and main() function entry after power-on?I control the PMIC with a normal GPIO push-pull output, and the output of the PMIC has a phenomenon similar to chopping.
danielmartynek
Hello @alphas,
I have difficulties to understand the description. Can you elaborate?
Anyway, the default out-of-reset PORT_PCR configuration of all the pins is specified in the IO_Signal_Description_Input_Multiplexing.xlsx, IO Signal Table, Column U.
Almost all the pins are in HI-Z state, and they remain in the state until they are reconfigured by the application.
alphas
@danielmartynek
hi,Could you please give me your email address? I will send you the materials returned to me by the supplier.
danielmartynek
Hi @alphas,
In this case, please create a ticket.
Put a link to this thread or my name to the description.
Thank you,
BR, Daniel
