S32DS Change MCU Partnumber
Alex_23
I based on K32K344 EVB evaluation function,the actual product will uses K314,I want to change the partnumber in S32DS 3.4.I want to know how to change the project's  MCU partnumer.
VaneB
Hi @Alex_23
I am afraid that the most viable option is to generate a new project with the corresponding MCU and then copy the application source files from your pre-existing project as well as any customizations you made to the project properties.
Sorry for the inconvenience.
B.R.
VaneB
Alex_23
OK, thank you.
