No such file or directory #include "Os_memmap.h"
shiqi_seventeen
Hello team,
I am following an online tutorial to use the S32K344 example code in S32DS to compile the configuration code generated by EB Tresos. However, during the compilation process in S32DS, I encountered an error message saying "No such file or directory #include "Os_memmap.h"". I searched my computer and found that this header file does not exist on my system.
Has anyone encountered this situation before, and how did you resolve it?
Thank you for your help.
VaneB
Hi @shiqi_seventeen
Did you have installed the corresponding RTD packages in S32DS? Could you share your installation details?
Also, a cause for this issue is due to an unmatch between the Tresos RTD version and the S32DS installed RTD version.
B.R.
VaneB
VaneB
Hi @shiqi_seventeen
B.R.
VaneB
