Need help with Fatal error: Failed to read CPUID for Cortex device
Andy_B
I am using an NXP S32K344EVB eval board with IAR Embedded Workbench, version 9.30.1.50054
When I try to download a program into the processor I get the subject error:
Any insight as to why this would be happening?  I'm new to both this processor and IAR, so any assistance would be appreciated.  Thank you.
Andy_B
Lukas,
The board is used.  After further investigation I noticed the a few jumpers weren't installed (J8, J10).  After inserting them everything is working as expected.  Thanks for your insight.
lukaszadrapa
Hi Andrew,
is that new EVB or used one? Do you know the history of this board?
It seems to be question rather for IAR or manufacturer of your debug probe. Is that jlink?
Lukas
