How the project in S32DS compile , link, make?
annqian
How the project in S32DS compile , link, make?  It is better for an example.
Tags (2)
martin_kovar
I am not sure, if I understand your question correct, but if you use S32DE IDE, you simply press Build button in the upper bar. This willexecute set of commands which compile and link the project and create .elf file.
You can also choose the build target you want to use. Please see the figure below:
Martin
annqian
thanks all right,but I want to know the diagram or theory of copile,link and make. source file like starup.c  ,the relation or diagram of S32k144_strup.s,and  xxx.ld .xxx.lanuch  ?
