Execute code on startup
B32bX
I programmed a few ports on my microcontroller to output a PWM signal. But when I turn my microcontroller off and on again it isn't executing my PWM code. I need to reprogram it again on every startup.
I want the microcontroller to automatically execute my written code on startup. How can this be done?
I am using the S32 Design Studio IDE and S32K118 microcontroller family.
Senlent
Hi@B32bX
It looks like you are downloading the code to RAM instead of flash, you can try downloading the code to the flash area.
You can refer to the attachment.
BR!
