Disable global interrupts at Watchdog configuration
2,472 次查看
adrianwenger
i want to configure the watchdog after reset.
There is a example code snippet in the reference Manual.
I used this in my s32 project, but an error appered: Symbol "DisableInterrupts" could not be resolved???
regards,
Adrian
标签 (1)
2 回复数
2,107 次查看
AdrianR
Hi Adrian,
Reference manual contains more like a "pseudo" code.
Try these instead:
DISABLE_INTERRUPTS();
ENABLE_INTERRUPTS();
Also,
Check out the WDOG example that comes with S32DS/SDK.
Adrian R.
2,107 次查看
adrianwenger
thanks now it works :smileyhappy:
