Hi Rajesh,
The warning informs you that the SPLL_CLK frequency must be between 90 MHz and 160 MHz.
So, I recommend you to set the SPLL_CLK = 160 MHz and for SYS_CLK set SPLL_CLK/2. After that, you reach SYS_CLK = 80 MHz without warnings.
I hope it helps you.
If you have any questions, let me know.
Diana
hi Diana ,
Thanks for answer .
its is not related to the software issue its hardware problem .
on more problem I am facing with Latest SDK os millisecond function not working .interrupt not triggering.
Rajesh Kota.
Hi Rajesh,
However, I have seen in your attachment a warning below because the PLL frequency is not within the range.
Regarding your second question, could you please provide more information such as a piece of your code settings?
Thank you.
Diana
