Hi, I am trying to install the HSE FW, but when I modified the UTEST(0x1B00_0000) to any value ,and download hse fw pink image to dix address and also set the IVT hse fw image address, after I opeated those steps, I find the debug is always failed by S32DS using any project. the following information always pop up. How to fix this issue.
Solved! Go to Solution.
For users who use PEMicro debugger, the user needs to change the PE debugger Flash Algorithm Selection after installing HSE-FW, this is necessary for all projects.
By the way: For users who use PEMicro debugger, it is recommended to refer to S32K3 MCUs for General Purpose HSE Demo Examples(S32K3_HSE_DemoExamples).
Robin
Robin
