We are using S32K322 100-Pin in our design. As per the datasheet, the V15 is powering from the 3.3V through a Ballast Transistor. The transistor is controlled by VCTRL pin in the microcontroller.
What is the Voltage/ Freq of VCTRL pin while controlling the ballast circuit?
What is the Extal Crystal enable pins voltage?
Hi @Chinnan,
This is liner regulator, it controls the VRC_CTRL continuously in the VDD_HV_NPN range.
Refer to the Hardware Design Guidelines for S32K3xx Microcontrollers
https://www.nxp.com/webapp/Download?colCode=S32K3_HW-DesignPackage
The EXTAL voltage depends on FXOSC_CTRL[ALC_D].
DS, Table 42. Fast External Oscillator
