pf53 footprint
pf53 footprint
ilir
hi apparently my pcb designer cant find the footprint of pf53 for the s32g2 design can someone share it pls with the library thx
https://www.nxp.com/products/power-management/pmics-and-sbcs/pmics/12-a-8-a-15-a-core-supply-regulat...
diazmarin09
I hope all is great with you. Thank you for using the NXP communities.
Do you mean the S32G-VNP-EVB3? Please review the design resources from the webpage for further information.
I hope this information helps.
David
ilir
we are having the following problem i dont know why maybe we can talk in private if you dont want something publicly
diazmarin09
I hope the material provided will be useful for you.
You can submit a new case regarding your new issue.
Please let me know if you have any further problem.
David
ilir
ok thank you ive sent it waiting to check and i will reply thanks again
