about add M.2 SSD disk for S32G ?
hardy2023
hi, experts,
I am working with  S32G  with a ubuntu 18.04 used SD card as boot device,
and I found the read write speed is realy slow , I use some tool have a test.
with 1G file random IO test .
Read 14.7 M/S
Write 3.42 M/S
it's slow to run my docker system.
So I want add a M.2 SSD disk for S32G.
for the board has a M.2 E-key Slot (J47) and M.2 M-key Slot  (J56) ,maybe can insert a SSD?
did any one know which SSD can work with this slot, or any suggestion about speed up IO?
