How to run m7 core os with power-on method ?
fengxianeric
Hi, I am building FreeRTOS_Toggle_Led_Example_S32G399A_M7 sample project, and wondering how to run os image standalone without debugging method ?   Thanks.
Daniel-Aguirre
The recommended method is the creation of an IVT/Blob image, then flashing it to the external memory of use.
If you are trying to load the binaries from uboot, there is no documentation nor recommendations (aside from the ones used under the IPCF example). We do apologize.
Please, let us know.
Daniel-Aguirre
You can define an IVT and create the Blob image for it to be loaded either to the QSPI or SD/MMC interface. For steps on how to do it, we can recommend the "Software Enablement Guide" available under the RDB3 product page (link: S32G3 Vehicle Networking Reference Design | NXP Semiconductors).
In there, steps on how to create the IVT and Blob image are provided, as well as the flashing process.
fengxianeric
BTW, for current stage it is acceptable for us to invoke it with similar ipcf testing instance method (startm7).
Daniel-Aguirre
