Hi, I build bootloader by command and tresos, but how to use ds to establish such project as doc mentioned below ?
The following HOWTO tells the steps to be able to debug a blob image loaded to NOR Flash:
HOWTO: JTAG Flash Programming with S32 Debugger an... - NXP Community
We recommend starting from an easier project, like a blink, to understand the process to be able to debug from external flash.
Please, let us know.
Thanks caring.
Yes I know how to do programming.
and how to connect debugger.
My point is how to build Ds boot loader project because I did by eb project plus make according doc guide.
Thanks again
Thanks for your feedback.
At this moment, there is no bootloader project available under S32DS. The image you shared was a debugging session under S32DS, hence we shared on how to debug under S32DS. We apologize.
