Installing new SDK causes automation project migration
已解决
跳至解决方案
2,189 次查看
sstelmak
I have S32 DS 3.5 and S32K344 micro.
It was originally set with SDK/RTD V2.0.0
It became necessary to add SDK 4.0.0, so that one project would migrate to 4.0.0 and another project stays at 2.0.0
SDK 4.0.0 gets installed properly and both SDKs appear under project settings.
I was expecting that by attaching/detaching SDK I can control which SDK current project would use.
However those "attached/detached" check-boxes seems to have no effect.
Regardless of that all projects would use 4.0.0 and it is was not possible to keep one project with 2.0.0
Is there a way to avoid that?
1 解答
2,130 次查看
sstelmak
That works, thank you
在原帖中查看解决方案
2 回复数
2,131 次查看
sstelmak
2,166 次查看
lukaszadrapa
Hi @sstelmak
S32DS 3.5 can keep one RTD version only (plus additional extensions packages/stacks).
The solution is to install more S32DS instances. Just use different folder name of S32DS like:
c:\NXP\S32DS.3.5_RTD_200\
c:\NXP\S32DS.3.5_RTD_400\
And install corresponding RTD package to those instances.
Lukas
%3CLINGO-SUB%20id%3D%22lingo-sub-1891676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%AE%89%E8%A3%85%E6%96%B0%E7%9A%84%20SDK%20%E4%BC%9A%E5%AF%BC%E8%87%B4%E8%87%AA%E5%8A%A8%E5%8C%96%E9%A1%B9%E7%9B%AE%E8%BF%81%E7%A7%BB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1891676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%9C%89%20S32%20DS%203.5%20%E5%92%8C%20S32K344%20micro%E3%80%82%3C%2FP%3E%3CP%3E%E5%8E%9F%E6%9C%AC%E6%98%AF%E7%94%A8SDK%2FRTD%20V2.0.0%E8%AE%BE%E7%BD%AE%E7%9A%84%3C%2FP%3E%3CP%3E%E6%9C%89%E5%BF%85%E8%A6%81%E6%B7%BB%E5%8A%A0%20SDK%204.0.0%EF%BC%8C%E8%BF%99%E6%A0%B7%EF%BC%8C%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E5%B0%86%E8%BF%81%E7%A7%BB%E5%88%B0%204.0.0%EF%BC%8C%E8%80%8C%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E4%BB%8D%E4%BF%9D%E7%95%99%E5%9C%A8%202.0.0%3C%2FP%3E%3CP%3ESDK%204.0.0%20%E5%B7%B2%E6%AD%A3%E7%A1%AE%E5%AE%89%E8%A3%85%EF%BC%8C%E5%B9%B6%E4%B8%94%E4%B8%A4%E4%B8%AA%20SDK%20%E9%83%BD%E5%87%BA%E7%8E%B0%E5%9C%A8%E9%A1%B9%E7%9B%AE%E8%AE%BE%E7%BD%AE%E4%B8%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B8%8C%E6%9C%9B%E9%80%9A%E8%BF%87%E9%99%84%E5%8A%A0%2F%E5%88%86%E7%A6%BB%20SDK%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E6%8E%A7%E5%88%B6%E5%BD%93%E5%89%8D%E9%A1%B9%E7%9B%AE%E5%B0%86%E4%BD%BF%E7%94%A8%E5%93%AA%E4%B8%AA%20SDK%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E8%80%8C%E9%82%A3%E4%BA%9B%E2%80%9C%E9%99%84%E5%8A%A0%2F%E5%88%86%E7%A6%BB%E2%80%9D%E5%A4%8D%E9%80%89%E6%A1%86%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E6%95%88%E6%9E%9C%E3%80%82%3C%2FP%3E%3CP%3E%E5%B0%BD%E7%AE%A1%E5%A6%82%E6%AD%A4%EF%BC%8C%E6%89%80%E6%9C%89%E9%A1%B9%E7%9B%AE%E9%83%BD%E4%BC%9A%E4%BD%BF%E7%94%A8%204.0.0%EF%BC%8C%E5%B9%B6%E4%B8%94%E4%B8%8D%E5%8F%AF%E8%83%BD%E8%AE%A9%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E7%BB%A7%E7%BB%AD%E4%BD%BF%E7%94%A8%202.0.0%3C%2FP%3E%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E4%BB%80%E4%B9%88%E5%8A%9E%E6%B3%95%E5%8F%AF%E4%BB%A5%E9%81%BF%E5%85%8D%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1892974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%AE%89%E8%A3%85%E6%96%B0%E7%9A%84%20SDK%20%E4%BC%9A%E5%AF%BC%E8%87%B4%E8%87%AA%E5%8A%A8%E5%8C%96%E9%A1%B9%E7%9B%AE%E8%BF%81%E7%A7%BB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1892974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%89%E6%95%88%EF%BC%8C%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E
