how to get stack pointer (SP)
mikoran
can you help me get the value of the stack pointer?
i am working on a module where I would monitor the value of the stack pointer and the program counter upon access violation.
I have this code in my interrupt handler:
    ISR void CPU12MPU_ISR(void) {
        __asm sts u16sp
        __asm movw 8,SP,u16pc
        S12XAccessViolation_ISR();
The problem with this code was it will have an endless loop executing __asm sts u16sp.
Is there any way I could get the value of SP?
CrasyCat
Specialist III
Hello
What about
   TFR SP, D
   STD u16sp
CrasyCat
mikoran
ok tnx.
it works..
