HI
void reset {COPCTL = 0x01; ARMCOP = 0x00;} I call this function in main(),but it is not reset. the code is running. why? Do I make some mistake?
Your code is right, which mode of the MCU do you use? The asynchronous reset like COP is not debuggable by BDM. See case: https://community.nxp.com/message/960909
Diana
