Please refer to the following build commands.
$ export PATH=/home/b25805/test/QorIQ-SDK-V1.9-20151210-yocto/build_t4240rdb-64b/tmp/sysroots/x86_64-linux/usr/bin/powerpc64-fsl-linux/:$PATH
$ make ARCH=powerpc uImage CROSS_COMPILE="powerpc64-fsl-linux-" CC="powerpc64-fsl-linux-gcc --sysroot=/home/b25805/test/QorIQ-SDK-V1.9-20151210-yocto/build_t4240rdb-64b/tmp/sysroots/t4240rdb-64b" o=temp LD=powerpc64-fsl-linux-ld.bfd
Yiping
Yiping
thanks, and I also use 'make O=temp CC=$CC LD=$LD' to resolve the problem.
