t1042 DDR3 memory lose data
923件の閲覧回数
uvmbox
I have t1042 custom board. i use QCVS to check initialization data, and calibarate memory. it passed all memory write-read tests. But when i start dubugger memory does not work. I see my custom DEADBEE5 initial data in memory monitor, but when i write FFFFFFFF   most of cell becomes 00000000.  and i cant run any application from RAM. i have several of MT18KSF51272HZ-1G6K2ZF SO-DIMM module the same behavior.pastedImage_2.png
## Target initialization file - DDR controller 1 section #
## Copyright : 2016 NXP, Inc. All Rights Reserved.
## SOURCE DISTRIBUTION PERMISSIBLE as directed in End User License Agreement.
## http : www.nxp.com
## mail : support@nxp.com
proc value_of {x} {
return $x
# DDR Controller 1 Registers
# DDR_SDRAM_CFG
mem i:0xFE008110 = [value_of 0x67200000]
# CS0_BNDS
mem i:0xFE008000 = [value_of 0x7F]
# CS1_BNDS
mem i:0xFE008008 = [value_of 0x0100017F]
# CS2_BNDS
mem i:0xFE008010 = [value_of 0x018001BF]
# CS3_BNDS
mem i:0xFE008018 = [value_of 0x01C001FF]
# CS0_CONFIG
mem i:0xFE008080 = [value_of 0x80004302]
# CS1_CONFIG
mem i:0xFE008084 = [value_of 0x80044302]
# CS2_CONFIG
mem i:0xFE008088 = [value_of 0x00010202]
# CS3_CONFIG
mem i:0xFE00808C = [value_of 0x00010202]
# CS0_CONFIG_2
mem i:0xFE0080C0 = [value_of 0x00]
# CS1_CONFIG_2
mem i:0xFE0080C4 = [value_of 0x00]
# CS2_CONFIG_2
mem i:0xFE0080C8 = [value_of 0x00]
# CS3_CONFIG_2
mem i:0xFE0080CC = [value_of 0x00]
# TIMING_CFG_3
mem i:0xFE008100 = [value_of 0x01071000]
# TIMING_CFG_0
mem i:0xFE008104 = [value_of 0x8055000C]
# TIMING_CFG_1
mem i:0xFE008108 = [value_of 0xBCB48C57]
# TIMING_CFG_2
mem i:0xFE00810C = [value_of 0x00411118]
# DDR_SDRAM_CFG_2
mem i:0xFE008114 = [value_of 0x00401050]
# DDR_SDRAM_MODE
mem i:0xFE008118 = [value_of 0x00441A71]
# DDR_SDRAM_MODE_2
mem i:0xFE00811C = [value_of 0x00180000]
# DDR_SDRAM_MODE_2
# DDR_SDRAM_MODE_2
# DDR_SDRAM_MODE_3
mem i:0xFE008200 = [value_of 0x00]
# DDR_SDRAM_MODE_4
mem i:0xFE008204 = [value_of 0x00]
# DDR_SDRAM_MODE_5
mem i:0xFE008208 = [value_of 0x00]
# DDR_SDRAM_MODE_6
mem i:0xFE00820C = [value_of 0x00]
# DDR_SDRAM_MODE_7
mem i:0xFE008210 = [value_of 0x00]
# DDR_SDRAM_MODE_8
mem i:0xFE008214 = [value_of 0x00]
# DDR_SDRAM_MD_CNTL
mem i:0xFE008120 = [value_of 0x00000000]
# DDR_SDRAM_INTERVAL
mem i:0xFE008124 = [value_of 0x18600618]
# DDR_DATA_INIT
mem i:0xFE008128 = [value_of 0xDEADBEE5]
# DDR_SDRAM_CLK_CNTL
mem i:0xFE008130 = [value_of 0x02000000]
# DDR_INIT_ADDR
mem i:0xFE008148 = [value_of 0x00000000]
# DDR_INIT_EXT_ADDR
mem i:0xFE00814C = [value_of 0x00000000]
# TIMING_CFG_4
mem i:0xFE008160 = [value_of 0x00220001]
# TIMING_CFG_5
mem i:0xFE008164 = [value_of 0x04401400]
# DDR_ZQ_CNTL
mem i:0xFE008170 = [value_of 0x89080600]
# DDR_WRLVL_CNTL
mem i:0xFE008174 = [value_of 0x8655F605]
# DDR_SR_CNTR
mem i:0xFE00817C = [value_of 0x00000000]
# DDR_WRLVL_CNTL_2
mem i:0xFE008190 = [value_of 0x0609050F]
# DDR_WRLVL_CNTL_3
mem i:0xFE008194 = [value_of 0x0B0D0B0A]
# DDR_ERR_DISABLE
mem i:0xFE008E44 = [value_of 0x00]
# DDR_ERR_INT_EN
mem i:0xFE008E48 = [value_of 0x1D]
# DDR_ERR_SBE
mem i:0xFE008E58 = [value_of 0x00010000]
# DDRCDR_1
mem i:0xFE008B28 = [value_of 0x80040000]
# DDRCDR_2
mem i:0xFE008B2C = [value_of 0x01]
# DDR_SDRAM_CFG_3
mem i:0xFE008260 = [value_of 0x00]
# TIMING_CFG_6
mem i:0xFE008168 = [value_of 0x00]
# TIMING_CFG_7
mem i:0xFE00816C = [value_of 0x00]
# TIMING_CFG_8
mem i:0xFE008250 = [value_of 0x00]
# DESKEW_CNTL
mem i:0xFE0082A0 = [value_of 0x00]
# DQ_MAP0
mem i:0xFE008400 = [value_of 0x00]
# DQ_MAP1
mem i:0xFE008404 = [value_of 0x00]
# DQ_MAP2
mem i:0xFE008408= [value_of 0x00]
# DQ_MAP3
# DDR_SDRAM_MODE_9
mem i:0xFE008220 = [value_of 0x00]
# DDR_SDRAM_MODE_10
mem i:0xFE008224 = [value_of 0x00]
# DDR_SDRAM_MODE_11
mem i:0xFE008228 = [value_of 0x00]
# DDR_SDRAM_MODE_12
mem i:0xFE00822C = [value_of 0x00]
# DDR_SDRAM_MODE_13
mem i:0xFE008230 = [value_of 0x00]
# DDR_SDRAM_MODE_14
mem i:0xFE008234 = [value_of 0x00]
# DDR_SDRAM_MODE_15
mem i:0xFE008238 = [value_of 0x00]
# DDR_SDRAM_MODE_16
mem i:0xFE00823C = [value_of 0x00]
# DDR_SDRAM_RCW_3
mem i:0xFE0081A0 = [value_of 0x00]
# DDR_SDRAM_RCW_4
mem i:0xFE0081A4 = [value_of 0x00]
# DDR_SDRAM_RCW_5
mem i:0xFE0081A8 = [value_of 0x00]
# DDR_SDRAM_RCW_6
mem i:0xFE0081AC = [value_of 0x00]
#Delay before enable
wait 500
#DDR_SDRAM_CFG
mem i:0xFE008110 = [value_of 0xE7200000]
# wait for DRAM data initialization
wait 1000
6 返答(返信)
846件の閲覧回数
uvmbox
There was wrong Clock Frequence setting in RCW . Solved.
846件の閲覧回数
Bulat
Following DDR3 setup is used on our development board with the same DIMMlike you use, please try it:
    # DDR Controller Setup
    # DDR_SDRAM_CFG
    mem [CCSR_ADDR 0x8110] = 0x67044000
    # DDR_CS0_BNDS
    mem [CCSR_ADDR 0x8000] = 0x000000ff
    # DDR_CS1_BNDS
    mem [CCSR_ADDR 0x8008] = 0x000000ff
    # DDR_CS0_CONFIG
    mem [CCSR_ADDR 0x8080] = 0x80044302
    # DDR_CS1_CONFIG
    mem [CCSR_ADDR 0x8084] = 0x80004302
    # DDR_CS0_CONFIG_2
    mem [CCSR_ADDR 0x80c0] = 0x00000000
    # DDR_CS1_CONFIG_2
    mem [CCSR_ADDR 0x80c4] = 0x00000000
    # DDR_TIMING_CFG_3
    mem [CCSR_ADDR 0x8100] = 0x01071000
    # DDR_TIMING_CFG_0
    mem [CCSR_ADDR 0x8104] = 0x5011000C
    # DDR_TIMING_CFG_1
    mem [CCSR_ADDR 0x8108] = 0xbcb58c56
    # DDR_TIMING_CFG_2
    mem [CCSR_ADDR 0x810C] = 0x0040c158
    # DDR_SDRAM_CFG_2
    mem [CCSR_ADDR 0x8114] = 0x00401111
    # DDR_SDRAM_MODE
    mem [CCSR_ADDR 0x8118] = 0x00441c70
    # DDR_SDRAM_MODE_2
    mem [CCSR_ADDR 0x811C] = 0x00980000
    # DDR_SDRAM_MODE_3
    mem [CCSR_ADDR 0x8200] = 0x00001c70
    # DDR_SDRAM_MODE_4
    mem [CCSR_ADDR 0x8204] = 0x00980000
    # DDR_SDRAM_MODE_5
    mem [CCSR_ADDR 0x8208] = 0x00001c70
    # DDR_SDRAM_MODE_6
    mem [CCSR_ADDR 0x820C] = 0x00000000
    # DDR_SDRAM_MODE_7
    mem [CCSR_ADDR 0x8210] = 0x00001c70
    # DDR_SDRAM_MODE_8
    mem [CCSR_ADDR 0x8214] = 0x00000000
    # DDR_SDRAM_MD_CNTL
    mem [CCSR_ADDR 0x8120] = 0x00000000
    mem [CCSR_ADDR 0x8124] = 0x0c300100
    # DDR_DATA_INIT
    mem [CCSR_ADDR 0x8128] = 0xdeadbeef
    mem [CCSR_ADDR 0x8130] = 0x02000000
    # DDR_INIT_ADDR
    mem [CCSR_ADDR 0x8148] = 0x00000000
    # DDR_INIT_EXT_ADDRESS
    mem [CCSR_ADDR 0x814C] = 0x00000000
    # DDR_TIMING_CFG_4
    mem [CCSR_ADDR 0x8160] = 0x00000001
    # DDR_TIMING_CFG_5
    mem [CCSR_ADDR 0x8164] = 0x04401400
    # DDR_ZQ_CNTL
    mem [CCSR_ADDR 0x8170] = 0x89080600
    # DDR_WRLVL_CNTL
    mem [CCSR_ADDR 0x8174] = 0xc675f607
    # DDR_SR_CNTR
    mem [CCSR_ADDR 0x817c] = 0x00000000
    # DDR_WRLVL_CNTL_2
    mem [CCSR_ADDR 0x8190] = 0x0808090b
    # DDR_WRLVL_CNTL_3
    mem [CCSR_ADDR 0x8194] = 0x0c0d0e0a
    # DDR_DDRCDR_1
    mem [CCSR_ADDR 0x8b28] = 0x80000000
    # DDR_DDRCDR_2
    mem [CCSR_ADDR 0x8b2c] = 0x00000000
    # DDR_ERR_DISABLE - DISABLE
    mem [CCSR_ADDR 0x8e44] = 0x00000000
    # DDR_ERR_SBE
    mem [CCSR_ADDR 0x8e58] = 0x00000000
    # delay before enable
    wait 500
    # DDR_SDRAM_CFG
    mem [CCSR_ADDR 0x8110] = 0xe7044000
    wait 1500
Bulat
846件の閲覧回数
uvmbox
cmdwin::mem i:0xfe0e2084 = 0x0000000F
ccs_write_memory
coreh = [serverh:0;cc_index:0;chain_pos:1]
addr = [space:0x9a;size:4;address_hi:0x00000000;address_lo:0xfe0e2084]
data: (size = 4)
0000000F
ccs_write_memory; ccs_error = 0; duration=1 ms
ccs_read_memory
addr = [space:0x90;size:4;address_hi:0x00000001;address_lo:0x00000000]
data: (size = 256)
00000000 00000000 00000000 00000000
ccs_read_memory; ccs_error = 0; duration=2 ms
ccs_read_memory
addr = [space:0x92;size:4;address_hi:0x00000000;address_lo:0x0ffffe00]
retry = 1
data: (size = 256)
00000000 00000000 575D0000 00000000
ccs_read_memory; ccs_error = 47; duration=21 ms
Error message: Scan timeout
ccs_core_run_mode
mode = 11
ccs_core_run_mode; ccs_error = 47
846件の閲覧回数
Bulat
RCW can be found below.
U-Boot 2014.07QorIQ-SDK-V1.7+g659b6a2 (Dec 13 2014 - 18:00:52)
CPU0:  T1040E, Version: 1.1, (0x85280011)
Core:  e5500, Version: 2.1, (0x80241021)
Clock Configuration:
       CPU0:1400 MHz, CPU1:1400 MHz, CPU2:1400 MHz, CPU3:1400 MHz,
       CCB:600  MHz,
       DDR:800  MHz (1600 MT/s data rate) (Asynchronous), IFC:150  MHz
       QE:300  MHz
       FMAN1: 600 MHz
       QMAN:  300 MHz
       PME:   300 MHz
L1:    D-cache 32 KiB enabled
       I-cache 32 KiB enabled
Reset Configuration Word (RCW):
       00000000: 0c18000e 0e000000 00000000 00000000
       00000010: 66000002 80000002 ec027000 01000000
       00000020: 00000000 00000000 00000000 00032810
       00000030: 00000000 0342500f 00000000 00000000
Board: T1040RDB
Board rev: 0x01 CPLD ver: 0x09, vBank: 0
I2C:   ready
SPI:   ready
DRAM:  Initializing....using SPD
Detected UDIMM 18KSF51272AZ-1G6K1
4 GiB (DDR3, 64-bit, CL=11, ECC on)
       DDR Chip-Select Interleaving Mode: CS0+CS1
Bulat
846件の閲覧回数
uvmbox
It does not work.
ccs_write_register
coreh = [serverh:0;cc_index:0;chain_pos:0]
index = 210014
count = 1
size = 4
value: (size = 4)
0342500F
ccs_write_register; ccs_error = 0; duration=2 ms
ccs_write_register
index = 210015
count = 1
size = 4
value: (size = 4)
00000000
ccs_write_register
index = 210016
count = 1
size = 4
value: (size = 4)
00000000
ccs_write_register; ccs_error = 0; duration=1 ms
ccs_reset_to_debug
serverh = 0
cc = 0
ccs_reset_to_debug; ccs_error = 39
Error message: T1040: Scan timeout
846件の閲覧回数
uvmbox
cs_core_run_mode
mode = 11
Can you provide your RCW?
