ls1043a how to write Ubuntu to emmc
hongyuanz
yipingwang
You could boot tiny Linux on the target board, and connecting the target board to Ethernet, then execute the following commands.
flex-installer -i pf -d /dev/mmcblk0
$ wget https://www.nxp.com/lgfiles/sdk/lsdk2108/boot_LS_arm64_lts_5.10.tgz
$ wget https://www.nxp.com/lgfiles/sdk/lsdk2108/rootfs_lsdk2108_ubuntu_main_arm64.tgz
$ flex-installer -b boot_LS_arm64_lts_5.10.tgz
-r rootfs_lsdk2108_ubuntu_main_arm64.tgz  -d /dev/mmcblk0
You also could run the above commands on the host PC.
$ wget https://www.nxp.com/lgfiles/sdk/lsdk2108/flex-installer && chmod +x flex-installer && sudo mv flex-installer /usr/bin
Please specify "-d" to emmc device name on the host PC.
