ls1021atwr build question
youyou
/work/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr$ bitbake fsl-image-minimal
In the /work/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr directory, compile by command bitbake fsl-image-minimal, it can build succeeded. But I moved the entire compiled code to another directory for compilation and failed to compile,such as: /work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr. We need more people to do development work at the same time, I need to modify the configuration files in the original compiled code environment so that I can compile and develop them in different directories of different computers? We don't want to delete the build_ls1021atwr folder and recompile it
I have modified the following documents, But a lot of mistakes
/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr$ bitbake fsl-image-minimalLoading cache: 100% |##########################################################################################################| ETA:  00:00:00
Loaded 3425 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION        = "1.28.0"
BUILD_SYS         = "i686-linux"
NATIVELSBSTRING   = "Ubuntu-14.04"
TARGET_SYS        = "arm-fsl-linux-gnueabi"
MACHINE           = "ls1021atwr"
DISTRO            = "fsl-qoriq"
DISTRO_VERSION    = "2.0"
TUNE_FEATURES     = "arm armv7a vfp neon callconvention-hard cortexa7"
TARGET_FPU        = "vfp-neon"
meta
meta-yocto
meta-yocto-bsp    = "HEAD:9a211a4a2c1bfcb292dc97d8dcac149bca9e3f1b"
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-xfce         = "HEAD:dc5634968b270dde250690609f0015f881db81f2"
meta-freescale    = "HEAD:7facbdb726e2dda0515e084c2066a4b8dd99c6d2"
meta-freescale-internal = "HEAD:4829293f807e35a1111e79763294fc8b98b97810"
meta-freescale-extra = "HEAD:bee911b027e0480b034674d0ddee3fcb06d2e985"
meta-virtualization = "HEAD:042425c1d98bdd7e44a62789bd03b375045266f5"
meta-java         = "HEAD:8b776ac68f9af4596be3824152bcf0bc6b67fa1d"
meta-openstack
meta-openstack-aio-deploy
meta-openstack-compute-deploy
meta-openstack-compute-test-config
meta-openstack-controller-deploy
meta-openstack-controller-test-config
meta-openstack-qemu
meta-openstack-swift-deploy
meta-cloud-services = "HEAD:d8bc0d92d0f741e2ea1e6d3d9bc6b7a091d03cfb"
meta-security     = "HEAD:f9367e71f923fc7d2fb600208e2b97535ea41777"
meta-linaro-toolchain = "HEAD:10b71bed9cfe76baa22c72806ff814cf85c2f73b"
NOTE: Preparing RunQueue
WARNING: /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-kernel/linux/linux-qoriq_4.1.bb.do_compile is tainted from a forced run
NOTE: Checking sstate mirror object availability (for 2 objects)
NOTE: Executing SetScene Tasks
ERROR: The recipe run-postinsts is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/run-postinsts
Please verify which recipe should provide the above files.
The build has stopped as continuing in this scenario WILL break things, if not now, possibly in the future (we've seen builds fail several months later). If the system knew how to recover from this automatically it would however there are several different scenarios which can result in this and we don't know which one this is. It may be you have switched providers of something like virtual/kernel (e.g. from linux-yocto to linux-yocto-dev), in that case you need to execute the clean task for both recipes and it will resolve this error. It may be you changed DISTRO_FEATURES from systemd to udev or vice versa. Cleaning those recipes should again resolve this error however switching DISTRO_FEATURES on an existing build directory is not supported, you should really clean out tmp and rebuild (reusing sstate should be safe). It could be the overlapping files detected are harmless in which case adding them to SSTATE_DUPWHITELIST may be the correct solution. It could also be your build is including two different conflicting versions of things (e.g. bluez 4 and bluez 5 and the correct solution for that would be to resolve the conflict. If in doubt, please ask on the mailing list, sharing the error and filelist above.
ERROR: If the above message is too much, the simpler version is you're advised to wipe out tmp and rebuild (reusing sstate is fine). That will likely fix things in most (but not all) cases.
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/all-fsl-linux/run-postinsts/1.0-r9/temp/log.do_populate_sysroot_setscene.4715
WARNING: Setscene task 87 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-devtools/run-postinsts/run-postinsts_1.0.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe u-boot-qoriq is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/ls1021atwr/u-boot-qoriq-dev-2016.01+fslgit-r0.ls1021atwr.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/ls1021atwr/u-boot-qoriq-2016.01+fslgit-r0.ls1021atwr.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/ls1021atwr/u-boot-qoriq-dbg-2016.01+fslgit-r0.ls1021atwr.rpm
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/ls1021atwr-fsl-linux-gnueabi/u-boot-qoriq/2016.01+fslgit-r0/temp/log.do_package_write_rpm_setscene.4713
WARNING: Setscene task 26 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-bsp/u-boot/u-boot-qoriq_2016.01.bb, do_package_write_rpm_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/u-boot-qoriq
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/virtual_bootloader
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/ls1021atwr-fsl-linux-gnueabi/u-boot-qoriq/2016.01+fslgit-r0/temp/log.do_populate_sysroot_setscene.4712
WARNING: Setscene task 20 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-bsp/u-boot/u-boot-qoriq_2016.01.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe createrepo-native is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/bin/rpm-createsolvedb.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/bin/modifyrepo
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/bin/createrepo.real
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/share/createrepo/readMetadata.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/share/createrepo/dumpMetadata.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/share/createrepo/modifyrepo.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/share/createrepo/genpkgmetadata.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/sysroot-providers/createrepo-native
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/i686-linux/createrepo-native/0.4.11-r9/temp/log.do_populate_sysroot_setscene.4714
WARNING: Setscene task 49 (virtual:native:/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-support/createrepo/createrepo_0.4.11.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/run-postinsts
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/run-postinsts-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/run-postinsts-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/run-postinsts-dev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/run-postinsts-doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/run-postinsts-locale
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/run-postinsts-dbg.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/run-postinsts.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/run-postinsts-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/run-postinsts-dev
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/all-fsl-linux/run-postinsts/1.0-r9/temp/log.do_packagedata_setscene.4755
WARNING: Setscene task 89 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-devtools/run-postinsts/run-postinsts_1.0.bb, do_packagedata_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe modutils-initscripts is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/modutils-initscripts
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/modutils-initscripts/1.0-r7/temp/log.do_populate_sysroot_setscene.4788
WARNING: Setscene task 241 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-kernel/modutils-initscripts/modutils-initscripts.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe base-passwd is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/base-passwd-dev-3.5.29-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/base-passwd-3.5.29-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/base-passwd-update-3.5.29-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/base-passwd-doc-3.5.29-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/base-passwd-dbg-3.5.29-r0.cortexa7hf_vfp_neon.rpm
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/base-passwd/3.5.29-r0/temp/log.do_package_write_rpm_setscene.4774
WARNING: Setscene task 234 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-core/base-passwd/base-passwd_3.5.29.bb, do_package_write_rpm_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/u-boot-qoriq
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq-doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq-dbg.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq-dev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq-images
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq-locale
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/u-boot-qoriq-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/u-boot-qoriq-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/u-boot-qoriq-dev
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/ls1021atwr-fsl-linux-gnueabi/u-boot-qoriq/2016.01+fslgit-r0/temp/log.do_packagedata_setscene.4770
WARNING: Setscene task 23 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-bsp/u-boot/u-boot-qoriq_2016.01.bb, do_packagedata_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/modutils-initscripts-dev-1.0-r7.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/modutils-initscripts-dbg-1.0-r7.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/modutils-initscripts-1.0-r7.cortexa7hf_vfp_neon.rpm
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/modutils-initscripts/1.0-r7/temp/log.do_package_write_rpm_setscene.4843
WARNING: Setscene task 246 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-kernel/modutils-initscripts/modutils-initscripts.bb, do_package_write_rpm_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/base-passwd
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-update
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-dbg.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-doc.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-dev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-update.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/base-passwd-locale
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/base-passwd
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/base-passwd-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/base-passwd-update
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/base-passwd-doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/base-passwd-dev
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/base-passwd/3.5.29-r0/temp/log.do_packagedata_setscene.4891
WARNING: Setscene task 231 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-core/base-passwd/base-passwd_3.5.29.bb, do_packagedata_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/modutils-initscripts
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/modutils-initscripts-locale
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/modutils-initscripts-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/modutils-initscripts-dev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/modutils-initscripts-dbg.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/modutils-initscripts.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/modutils-initscripts-doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/modutils-initscripts-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/modutils-initscripts-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/modutils-initscripts-dbg
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/modutils-initscripts/1.0-r7/temp/log.do_packagedata_setscene.4921
WARNING: Setscene task 243 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-kernel/modutils-initscripts/modutils-initscripts.bb, do_packagedata_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/base-passwd/group.master
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/base-passwd/passwd.master
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/base-passwd
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/base-passwd/3.5.29-r0/temp/log.do_populate_sysroot_setscene.5055
WARNING: Setscene task 229 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-core/base-passwd/base-passwd_3.5.29.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe lsbinitscripts is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/lsbinitscripts
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/lsbinitscripts/9.64-r0/temp/log.do_populate_sysroot_setscene.5062
WARNING: Setscene task 283 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-extended/lsb/lsbinitscripts_9.64.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/lsbinitscripts-dev-9.64-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/lsbinitscripts-9.64-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/lsbinitscripts-dbg-9.64-r0.cortexa7hf_vfp_neon.rpm
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/lsbinitscripts/9.64-r0/temp/log.do_package_write_rpm_setscene.5115
WARNING: Setscene task 288 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-extended/lsb/lsbinitscripts_9.64.bb, do_package_write_rpm_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/lsbinitscripts
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/lsbinitscripts.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/lsbinitscripts-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/lsbinitscripts-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/lsbinitscripts-dbg.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/lsbinitscripts-dev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/lsbinitscripts-doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/lsbinitscripts-locale
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/lsbinitscripts-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/lsbinitscripts-dbg
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/lsbinitscripts/9.64-r0/temp/log.do_packagedata_setscene.5188
WARNING: Setscene task 285 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-extended/lsb/lsbinitscripts_9.64.bb, do_packagedata_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe util-linux is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-fsck.cramfs-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-ja-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-eu-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-staticdev-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-readprofile-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-zh-tw-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-ru-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-cs-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-bash-completion-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/libblkid1-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-fstrim-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-findfs-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-id-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-fsck-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-fi-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-swaponoff-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-hu-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-zh-cn-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-vi-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/libsmartcols1-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-et-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-mkfs-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-blkid-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-agetty-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-de-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-pl-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-doc-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-gl-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-fdisk-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-tr-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/libmount1-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-uuidgen-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-reset-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-mkfs.cramfs-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-sfdisk-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-lscpu-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-getopt-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-partx-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-umount-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-sl-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-dev-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-sulogin-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-it-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-cfdisk-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-losetup-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-uuidd-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-es-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-uk-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-hr-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-pt-br-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-mcookie-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-dbg-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-sv-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-da-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-hwclock-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-ca-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/libuuid1-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-mount-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-fr-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/libfdisk1-2.26.2-r0.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/util-linux-locale-nl-2.26.2-r0.cortexa7hf_vfp_neon.rpm
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/util-linux/2.26.2-r0/temp/log.do_package_write_rpm_setscene.4920
WARNING: Setscene task 282 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-core/util-linux/util-linux_2.26.2.bb, do_package_write_rpm_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/lib/libuuid.so.1.3.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/lib/libsmartcols.so.1.1.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/lib/libblkid.so.1.1.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/lib/libfdisk.so.1.1.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/lib/libmount.so.1
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/lib/libmount.so.1.1.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/utmpdump
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/lsblk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/ionice
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/col
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/fstrim
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/rtcwake
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/sfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/wdctl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/wipefs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/whereis
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/delpart
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/setsid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/swapon
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/resizepart
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/ldattach
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/rename
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/mcookie
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/tailf
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/column
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/blockdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/write
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/look
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/chrt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/lscpu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/cal
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/colcrt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/fsck.cramfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/unshare
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/fallocate
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/isosize
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/mesg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/nsenter
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/findmnt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/blkid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/lslocks
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/blkdiscard
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/mkfs.bfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/hexdump
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/cfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/mkfs.minix
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/wall
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/mkfs.cramfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/renice
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/chcpu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/more
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/readprofile
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/taskset
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/addpart
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/scriptreplay
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/hwclock
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/setterm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/getopt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/ipcs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/last
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/losetup
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/prlimit
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/pg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/namei
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/fdformat
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/ipcrm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/fdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/colrm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/raw
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/fsfreeze
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/zramctl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/dmesg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/logger
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/uuidd
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/uuidgen
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/rev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/swaplabel
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/ctrlaltdel
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/setarch
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/flock
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/mkswap
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/ul
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/fsck.minix
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/pivot_root
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/partx
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/eject
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/share/bash-completion/completions/mountpoint
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libsmartcols.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libsmartcols.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libfdisk.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libuuid.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libuuid.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libmount.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libmount.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libblkid.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libblkid.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libuuid.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libfdisk.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libblkid.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libsmartcols.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libmount.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libfdisk.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/fdisk.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/uuid.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/smartcols.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/blkid.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/mount.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/libfdisk/libfdisk.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/blkid/blkid.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/libsmartcols/libsmartcols.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/uuid/uuid.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/libmount/libmount.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/util-linux
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/util-linux/2.26.2-r0/temp/log.do_populate_sysroot_setscene.4866
WARNING: Setscene task 277 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-core/util-linux/util-linux_2.26.2.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe binutils-native is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libbfd.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libopcodes.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libbfd.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libiberty.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libopcodes.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/plugin-api.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/ansidecl.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/dis-asm.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/bfd.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/symcat.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/bfdlink.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/partition.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/splay-tree.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/sort.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/ansidecl.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/fibheap.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/dyn-string.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/floatformat.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/objalloc.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/timeval-utils.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/safe-ctype.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/hashtab.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/demangle.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/libiberty/libiberty.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/sysroot-providers/binutils-native
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/i686-linux/binutils-native/linaro-2.25-r2015.01/temp/log.do_populate_sysroot_setscene.5171
WARNING: Setscene task 297 (virtual:native:/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-linaro/meta-linaro-toolchain/recipes-devtools/binutils/binutils_linaro-2.25.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe python is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-debugger-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-dev-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-xmlrpc-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-sqlite3-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-datetime-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-man-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-db-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-mime-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-audio-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-syslog-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/libpython2.7-1.0-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-resource-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-unittest-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-robotparser-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-pprint-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-importlib-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-netclient-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-tkinter-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-xml-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-unixadmin-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-image-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-2to3-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-fcntl-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-crypt-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-pickle-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-tests-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-dbg-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-logging-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-compiler-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-modules-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-gdbm-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-mmap-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-mailbox-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-numbers-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-readline-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-distutils-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-textutils-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-subprocess-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-codecs-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-argparse-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-distutils-staticdev-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-elementtree-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-idle-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-bsddb-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-hotshot-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-stringold-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-sqlite3-tests-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-smtpd-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-shell-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-contextlib-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-email-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-lang-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-multiprocessing-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-misc-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-re-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-html-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-pydoc-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-netserver-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-pkgutil-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-difflib-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-profile-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-curses-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-math-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-compile-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-compression-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-json-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-core-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-zlib-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-io-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-terminal-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-ctypes-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-doctest-2.7.9-r1.cortexa7hf_vfp_neon.rpm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/rpm/cortexa7hf_vfp_neon/python-threading-2.7.9-r1.cortexa7hf_vfp_neon.rpm
Please verify which recipe should provide the above files.
The build has stopped as continuing in this scenario WILL break things, if not now, possibly in the future (we've seen builds fail several months later). If the system knew how to recover from this automatically it would however there are several different scenarios which can result in this and we don't know which one this is. It may be you have switched providers of something like virtual/kernel (e.g. from linux-yocto to linux-yocto-dev), in that case you need to execute the clean task for both recipes and it will resolve this error. It may be you changed DISTRO_FEATURES from systemd to udev or vice versa. Cleaning those recipes should again resolve this error however switching DISTRO_FEATURES on an existing build directory is not supported, you should really clean out tmp and rebuild (reusing sstate should be safe). It could be the overlapping files detected are harmless in which case adding them to SSTATE_DUPWHITELIST may be the correct solution. It could also be your build is including two different conflicting versions of things (e.g. bluez 4 and bluez 5 and the correct solution for that would be to resolve the conflict. If in doubt, please ask on the mailing list, sharing the error and filelist above.
ERROR: If the above message is too much, the simpler version is you're advised to wipe out tmp and rebuild (reusing sstate is fine). That will likely fix things in most (but not all) cases.
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/python/2.7.9-r1/temp/log.do_package_write_rpm_setscene.5731
WARNING: Setscene task 402 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-devtools/python/python_2.7.9.bb, do_package_write_rpm_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/util-linux
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/cs-translation/util-linux-locale-cs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/hu-translation/util-linux-locale-hu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/nl-translation/util-linux-locale-nl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/sl-translation/util-linux-locale-sl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/ca-translation/util-linux-locale-ca
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/es-translation/util-linux-locale-es
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libblkid-dev/util-linux-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libmount-dev/util-linux-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/da-translation/util-linux-locale-da
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/zh-tw-translation/util-linux-locale-zh-tw
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libsmartcols/util-linux-libsmartcols
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/uk-translation/util-linux-locale-uk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libmount/util-linux-libmount
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-id
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-hr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-pt-br
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-vi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-it
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-sv
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-nl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-pl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-cs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-de
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-fr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-fi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-ru
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-eu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-hu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-uk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-ja
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-tr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-zh-cn
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-ca
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-es
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-da
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-sl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-gl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-et
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-locale/util-linux-locale-zh-tw
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/tr-translation/util-linux-locale-tr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/et-translation/util-linux-locale-et
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libblkid/util-linux-libblkid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libfdisk/util-linux-libfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/(=2.26.2)/util-linux-libsmartcols
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/(=2.26.2)/util-linux-libmount
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/(=2.26.2)/util-linux-libblkid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/(=2.26.2)/util-linux-libfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/(=2.26.2)/util-linux-libuuid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/ru-translation/util-linux-locale-ru
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/zh-cn-translation/util-linux-locale-zh-cn
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/de-translation/util-linux-locale-de
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/ja-translation/util-linux-locale-ja
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libuuid-dev/util-linux-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/pl-translation/util-linux-locale-pl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/it-translation/util-linux-locale-it
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/util-linux-libuuid/util-linux-libuuid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/eu-translation/util-linux-locale-eu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/vi-translation/util-linux-locale-vi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/sv-translation/util-linux-locale-sv
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/id-translation/util-linux-locale-id
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/gl-translation/util-linux-locale-gl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/fi-translation/util-linux-locale-fi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/hr-translation/util-linux-locale-hr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/fr-translation/util-linux-locale-fr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/pt-br-translation/util-linux-locale-pt-br
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-mkfs.cramfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-da.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-readprofile
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-sl.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-readprofile.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-id
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-hu.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-mcookie.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-fsck.cramfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-zh-cn.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-bash-completion.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-staticdev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-reset
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-fstrim.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-hr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-pt-br
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-vi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-mount
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-it
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-mount.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libuuid.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-umount.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-losetup
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-sv
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-fr.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-id.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-nl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-dev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-uuidgen.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libsmartcols
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-pl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-cs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-blkid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-swaponoff.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-es.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libmount
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-sfdisk.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-findfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-partx
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-mkfs.cramfs.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-de
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-losetup.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-partx.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-et.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-lscpu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-getopt.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libblkid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-fi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-reset.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-cfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-findfs.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-ru
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-eu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-dbg.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libmount.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-fi.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-agetty
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-uk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-vi.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-gl.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-fdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-sulogin.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-ja
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-cs.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-de.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-mkfs.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-ja.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-doc.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-tr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-lscpu.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-hr.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-nl.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-sv.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-pt-br.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-uk.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-fsck.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-uuidd.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-fdisk.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-ca
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libsmartcols.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-pl.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-fsck.cramfs.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-tr.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-blkid.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-eu.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-it.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-ru.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-zh-tw.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-hwclock
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-hwclock.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libfdisk.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-cfdisk.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-libblkid.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-agetty.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/util-linux-locale-ca.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-mkfs.cramfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-readprofile
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-id
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-fsck.cramfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-reset
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-hr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/libuuid1
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-fstrim
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-pt-br
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-vi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-mount
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-it
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-losetup
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-bash-completion
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-sv
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-nl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-mcookie
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-pl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-cs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-blkid
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-findfs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-partx
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-de
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-fr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-lscpu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-umount
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-fi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-cfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-ru
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-eu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-agetty
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-hu
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-uk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-fdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-getopt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/libmount1
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-ja
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-sulogin
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-tr
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/libfdisk1
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/libsmartcols1
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-zh-cn
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-ca
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-uuidd
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-swaponoff
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-es
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/libblkid1
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-da
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-uuidgen
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-hwclock
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-sl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-gl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-et
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-locale-zh-tw
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/util-linux-sfdisk
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/util-linux-libblkid.list
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/util-linux-libmount.list
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/util-linux-libfdisk.list
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/util-linux-libsmartcols.list
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/util-linux-libuuid.list
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/util-linux-dev.pclist
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/util-linux/2.26.2-r0/temp/log.do_packagedata_setscene.5622
WARNING: Setscene task 279 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-core/util-linux/util-linux_2.26.2.bb, do_packagedata_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe ossp-uuid-native is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/bin/uuid-config
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libossp-uuid.la
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libossp-uuid.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libossp-uuid.so.16
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/libossp-uuid.so.16.0.22
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/lib/pkgconfig/ossp-uuid.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/usr/include/ossp/uuid.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/i686-linux/sysroot-providers/ossp-uuid-native
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/i686-linux/ossp-uuid-native/1.6.2-r2/temp/log.do_populate_sysroot_setscene.6897
WARNING: Setscene task 169 (virtual:native:/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-devtools/ossp-uuid/ossp-uuid_1.6.2.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/python
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/libpython2/libpython2
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/python/python-core
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-rprovides/(=2.7.9)/libpython2
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-elementtree.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-unixadmin
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-xml.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-mime.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-unittest.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-io.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-stringold.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-distutils
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-idle.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-netclient.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-readline.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-audio
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-syslog
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-mmap
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-core.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-math.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-crypt.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-misc.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-multiprocessing
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-compiler
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-tkinter
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-modules
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-curses.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-argparse.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-importlib.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-terminal.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-profile
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-tests
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-syslog.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-netserver.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-pprint
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-pickle.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-html
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-threading.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-image
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-unixadmin.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-shell
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-json
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-pprint.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-audio.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-numbers
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-modules.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-lang.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-sqlite3-tests.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-xmlrpc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-compression
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-debugger.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-html.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-mmap.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-distutils-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-datetime.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-db.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-image.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-mailbox
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-hotshot
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-fcntl.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-zlib.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-dbg.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-compiler.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-robotparser.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-email
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-man.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/libpython2
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-resource
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-subprocess
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-logging
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-tkinter.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-doctest.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-logging.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-textutils.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-pydoc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-contextlib.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-distutils-staticdev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-difflib
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-resource.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-2to3
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-2to3.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-sqlite3.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-json.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-shell.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-re.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-compression.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-smtpd.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-dev.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-difflib.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-distutils.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-hotshot.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-bsddb
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-profile.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-compile.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-mailbox.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-tests.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-pydoc.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-numbers.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-pkgutil
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-ctypes.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-gdbm.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-codecs.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-bsddb.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-email.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-xmlrpc.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-pkgutil.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-subprocess.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/python-multiprocessing.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime/libpython2.packaged
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-unixadmin
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-xml
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-distutils
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-audio
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-syslog
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-re
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-mmap
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-multiprocessing
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-compiler
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-tkinter
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-modules
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-profile
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-tests
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-pprint
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-html
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-unittest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-image
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-elementtree
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-shell
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-json
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-numbers
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-xmlrpc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-compression
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-distutils-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-crypt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-stringold
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-argparse
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-mailbox
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-hotshot
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-mime
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-db
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-datetime
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-debugger
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-fcntl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-lang
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-idle
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-email
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-resource
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-subprocess
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-logging
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-threading
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-robotparser
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-terminal
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-pydoc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-difflib
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-importlib
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-curses
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-2to3
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-math
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-core
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-pickle
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-contextlib
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-smtpd
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-bsddb
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-netserver
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-sqlite3
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-doctest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-misc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-pkgutil
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-sqlite3-tests
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/libpython2.7-1.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-textutils
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-zlib
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-man
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-ctypes
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-dbg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-codecs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-netclient
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-readline
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-io
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/runtime-reverse/python-gdbm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/libpython2.list
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/pkgdata/shlibs2/python-dev.pclist
Please verify which recipe should provide the above files.
The build has stopped as continuing in this scenario WILL break things, if not now, possibly in the future (we've seen builds fail several months later). If the system knew how to recover from this automatically it would however there are several different scenarios which can result in this and we don't know which one this is. It may be you have switched providers of something like virtual/kernel (e.g. from linux-yocto to linux-yocto-dev), in that case you need to execute the clean task for both recipes and it will resolve this error. It may be you changed DISTRO_FEATURES from systemd to udev or vice versa. Cleaning those recipes should again resolve this error however switching DISTRO_FEATURES on an existing build directory is not supported, you should really clean out tmp and rebuild (reusing sstate should be safe). It could be the overlapping files detected are harmless in which case adding them to SSTATE_DUPWHITELIST may be the correct solution. It could also be your build is including two different conflicting versions of things (e.g. bluez 4 and bluez 5 and the correct solution for that would be to resolve the conflict. If in doubt, please ask on the mailing list, sharing the error and filelist above.
ERROR: If the above message is too much, the simpler version is you're advised to wipe out tmp and rebuild (reusing sstate is fine). That will likely fix things in most (but not all) cases.
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/python/2.7.9-r1/temp/log.do_packagedata_setscene.6899
WARNING: Setscene task 399 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-devtools/python/python_2.7.9.bb, do_packagedata_setscene) failed with exit code '1' - real task will be run instead
ERROR: The recipe python is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
   /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libpython2.7.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/libpython2.7.so.1.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/python.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/python-2.7.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/pkgconfig/python2.pc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cProfile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bisect.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/Cookie.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/asynchat.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre_compile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/io.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pyclbr.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/zipfile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mailbox.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/htmllib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/urllib2.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/heapq.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/MimeWriter.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pdb.doc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/htmlentitydefs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/md5.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/wsgiref.egg-info
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/zipfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cProfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pipes.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/imaplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sitecustomize.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/nturl2path.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pydoc.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/argparse.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/this.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pkgutil.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/keyword.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ihooks.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/__phello__.foo.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pty.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cookielib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre_parse.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/macpath.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/binhex.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/difflib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/functools.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/keyword.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/webbrowser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/fileinput.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sndhdr.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mailcap.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mimetools.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/os2emxpath.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cmd.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/imputil.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/fpformat.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/getpass.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/hmac.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pprint.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/telnetlib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_weakrefset.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/macpath.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/shelve.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/code.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/aifc.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sysconfig.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/urllib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/base64.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/repr.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/trace.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/genericpath.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/netrc.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_osx_support.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/rfc822.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/colorsys.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/linecache.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ihooks.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multifile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sgmllib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/gettext.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/argparse.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/plistlib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pyclbr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/commands.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/nntplib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/stat.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/SimpleHTTPServer.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre_compile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/smtplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/wave.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/traceback.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/atexit.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/csv.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/locale.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/LICENSE.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compileall.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/UserString.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/poplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mimetypes.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/stringold.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sets.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/posixfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sched.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/fractions.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/py_compile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/warnings.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/dummy_threading.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/stringprep.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/smtpd.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/optparse.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/platform.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/random.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/UserList.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/opcode.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xmllib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cgitb.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/hashlib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/tabnanny.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/SimpleXMLRPCServer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/fnmatch.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sha.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/rexec.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ssl.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/profile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/base64.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bdb.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/stat.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/posixpath.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/asyncore.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/tokenize.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/string.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/decimal.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/anydbm.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/repr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pickletools.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/textwrap.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/robotparser.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_strptime.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/__phello__.foo.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pty.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/py_compile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sha.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/runpy.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/toaiff.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/smtpd.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/contextlib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ntpath.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/opcode.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/uu.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/numbers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cgi.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ftplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/symtable.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ast.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/CGIHTTPServer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/dbhash.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xmlrpclib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/commands.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/timeit.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/urlparse.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_LWPCookieJar.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ConfigParser.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mutex.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/UserDict.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/macurl2path.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/shutil.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/BaseHTTPServer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/copy_reg.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/site.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/tarfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/inspect.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sndhdr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/new.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pdb.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/gzip.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/dumbdbm.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_MozillaCookieJar.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre_parse.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/uuid.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pprint.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_pyio.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/rlcompleter.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/doctest.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/chunk.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/platform.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/atexit.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre_constants.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/inspect.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/anydbm.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/dis.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/urllib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sunaudio.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/collections.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/dis.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_sysconfigdata.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/shlex.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/profile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/dummy_thread.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/netrc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/socket.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/DocXMLRPCServer.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/contextlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/telnetlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_LWPCookieJar.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/doctest.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/Bastion.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/aifc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mimetools.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/symbol.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/httplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sunau.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/__future__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/codecs.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/os.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre_constants.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/markupbase.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/csv.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/Queue.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/re.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/token.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cmd.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/UserList.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/UserString.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/chunk.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/traceback.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xmlrpclib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/threading.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/rfc822.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cgitb.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ssl.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/threading.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sre.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mimify.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sunaudio.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/calendar.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/copy.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/HTMLParser.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/MimeWriter.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/Bastion.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/tempfile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/struct.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sysconfig.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/getopt.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/calendar.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/markupbase.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/filecmp.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/SimpleHTTPServer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/filecmp.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/SocketServer.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/tabnanny.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/HTMLParser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/rlcompleter.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/audiodev.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/statvfs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/weakref.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/macurl2path.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_threading_local.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/warnings.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mimify.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bdb.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sunau.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/nntplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/struct.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xdrlib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/copy_reg.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/wave.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/popen2.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bisect.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_abcoll.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/whichdb.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/quopri.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/dumbdbm.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/weakref.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/antigravity.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/tempfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_MozillaCookieJar.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/symbol.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/urllib2.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/codecs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sets.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/subprocess.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_abcoll.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/hashlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/subprocess.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/glob.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/codeop.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/plistlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/quopri.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/imghdr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/abc.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/user.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/copy.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pickle.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/dircache.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/getopt.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/types.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/_weakrefset.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/re.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/audiodev.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mhlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ConfigParser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pstats.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/modulefinder.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xdrlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/glob.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/formatter.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/modulefinder.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mutex.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/StringIO.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/os2emxpath.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/Cookie.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multifile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/abc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/decimal.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sched.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/UserDict.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/DocXMLRPCServer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/tty.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/user.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/cookielib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/token.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pydoc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/linecache.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/urlparse.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/SocketServer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pickle.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/tty.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/nturl2path.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/robotparser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/mailcap.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/readline.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_io.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/operator.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/dl.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/select.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_locale.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_hotshot.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_elementtree.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_curses_panel.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/dbm.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_codecs_tw.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_heapq.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_socket.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_json.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/math.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/syslog.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/nis.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_sqlite3.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_codecs_cn.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_ctypes_test.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_ssl.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_ctypes.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/imageop.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_testcapi.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_csv.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/Python-2.7.9-py2.7.egg-info
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/bz2.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/time.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_codecs_jp.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/unicodedata.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/parser.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/strop.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/fcntl.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/pyexpat.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/cStringIO.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/future_builtins.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_random.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_multibytecodec.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/datetime.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/audioop.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_curses.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_lsprof.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/array.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/cmath.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/zlib.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/spwd.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_collections.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/resource.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/grp.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/cPickle.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_struct.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/itertools.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/termios.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_hashlib.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/crypt.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_multiprocessing.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/binascii.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_codecs_iso2022.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_bisect.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/mmap.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_functools.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_codecs_kr.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/_codecs_hk.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-dynload/gdbm.so
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pydoc_data/topics.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/pydoc_data/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/sax/handler.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/sax/_exceptions.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/sax/saxutils.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/sax/xmlreader.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/sax/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/sax/expatreader.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/etree/ElementInclude.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/etree/ElementPath.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/etree/cElementTree.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/etree/ElementPath.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/etree/ElementTree.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/etree/ElementTree.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/etree/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/parsers/expat.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/parsers/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/parsers/expat.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/dom/expatbuilder.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/dom/pulldom.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/dom/minicompat.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/dom/NodeFilter.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/dom/NodeFilter.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/dom/xmlbuilder.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/dom/domreg.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/dom/xmlbuilder.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/dom/minidom.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/dom/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/dom/domreg.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/dom/minidom.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/xml/dom/minicompat.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/site-packages/README
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/logging/handlers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/logging/config.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/logging/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/importlib/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/dump.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/dbapi2.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/dbapi2.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/test/dump.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/test/factory.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/test/regression.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/test/transactions.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/test/regression.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/test/py25tests.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/test/dbapi.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/test/hooks.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/test/userfunctions.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/test/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/test/py25tests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/test/types.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/test/transactions.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/sqlite3/test/factory.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/dbrecio.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/dbutils.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/db.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/dbobj.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/dbshelve.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/dbtables.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/dbobj.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/dbutils.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/db.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/dbtables.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/dbshelve.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_db.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_basics.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_distributed_transactions.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_associate.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_distributed_transactions.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_get_none.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_compare.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_all.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_thread.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_dbshelve.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_cursor_pget_bug.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_compat.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_dbtables.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_sequence.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_thread.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_queue.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_replication.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_replication.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_fileid.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_misc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_recno.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_dbobj.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_all.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_early_close.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_pickle.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_dbenv.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_join.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_dbtables.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_pickle.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_lock.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_dbobj.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_dbshelve.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_associate.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/bsddb/test/test_fileid.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ensurepip/__main__.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ensurepip/_uninstall.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ensurepip/__main__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ensurepip/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ensurepip/_bundled/setuptools-7.0-py2.py3-none-any.whl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ensurepip/_bundled/pip-1.5.6-py2.py3-none-any.whl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/config/Setup
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/config/python.o
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/config/Makefile
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/config/install-sh
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/config/makesetup
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/config/config.c.in
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/config/Setup.config
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/config/libpython2.7.a
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/config/Setup.local
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/loader.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/__main__.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/signals.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/runner.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/main.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/case.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/util.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/result.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/suite.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/__main__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_result.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_suite.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_suite.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_program.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_runner.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_assertions.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_skipping.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_case.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_discovery.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_setups.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_assertions.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_loader.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/support.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_functiontestcase.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_break.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_break.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/dummy.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/dummy.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/unittest/test/test_loader.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/FileDialog.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/Tkconstants.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/Tkconstants.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/FileDialog.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/ScrolledText.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/Dialog.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/tkFileDialog.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/Tkinter.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/Tix.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/SimpleDialog.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/tkColorChooser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/tkFont.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/Dialog.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/Tkdnd.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/tkMessageBox.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/turtle.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/tkCommonDialog.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/tkSimpleDialog.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/tkSimpleDialog.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/FixTk.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/tkFont.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/ttk.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/Canvas.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/Tkdnd.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/Canvas.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/ttk.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/Tix.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/ScrolledText.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/SimpleDialog.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/widget_tests.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/README
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/runtktests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/widget_tests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_ttk/test_extensions.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_ttk/test_functions.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_ttk/test_style.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_ttk/test_widgets.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_ttk/test_style.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_ttk/test_functions.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_ttk/support.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_ttk/test_extensions.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_ttk/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_tkinter/test_loadtk.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_tkinter/test_font.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_tkinter/test_variables.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_tkinter/test_font.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_tkinter/test_images.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_tkinter/test_widgets.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_tkinter/test_text.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_tkinter/test_geometry_managers.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_tkinter/test_geometry_managers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_tkinter/test_text.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_tkinter/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib-tk/test/test_tkinter/test_variables.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/feedparser.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/charset.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/feedparser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/utils.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/generator.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/message.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/_parseaddr.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/iterators.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/base64mime.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/encoders.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/errors.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/encoders.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/parser.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/parser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/_parseaddr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/quoprimime.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/generator.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/header.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/base64mime.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/message.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/errors.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/mime/message.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/mime/base.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/mime/image.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/mime/application.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/mime/multipart.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/mime/audio.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/mime/nonmultipart.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/mime/text.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/mime/text.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/mime/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/mime/nonmultipart.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/mime/message.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/test_email_codecs.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/test_email_codecs_renamed.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/test_email_torture.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/test_email_renamed.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/test_email_torture.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/test_email.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/test_email_codecs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/test_email_renamed.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/test_email.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_32.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_36.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_12a.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_13.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_23.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_41.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_01.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_06.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_18.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_45.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_26.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_28.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_24.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_44.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_29.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_12.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_21.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_04.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_39.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_15.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_31.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_35.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_03.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/PyBanner048.gif
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_07.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_05.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_30.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_27.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_10.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_40.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_09.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_08.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_02.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_25.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_34.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_14.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_22.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_17.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_16.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_46.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_11.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_37.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/audiotest.au
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_42.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_19.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_38.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_43.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_33.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/email/test/data/msg_20.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/unicode_escape.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/palmos.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp500.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/euc_jp.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_13.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1006.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1254.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp720.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_turkish.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1140.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp858.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_romanian.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso2022_jp_2004.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp865.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1255.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/tis_620.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_iceland.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mbcs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/utf_16_be.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/hz.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/raw_unicode_escape.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_8.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/koi8_r.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/gbk.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1252.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/uu_codec.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/utf_16_le.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1253.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/ascii.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/gb2312.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/utf_32_le.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/shift_jisx0213.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp875.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/utf_16_be.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp856.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/hex_codec.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp858.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1257.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_latin2.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_15.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/utf_8.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/idna.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1250.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_10.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1256.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_5.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/koi8_u.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_5.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_croatian.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso2022_jp_3.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp863.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/koi8_r.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_romanian.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp864.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp950.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1026.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/shift_jis_2004.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/hex_codec.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/hz.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp949.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/johab.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_roman.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/utf_32.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_3.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/gb18030.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_16.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1026.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/zlib_codec.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso2022_jp_ext.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp932.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/base64_codec.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp869.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/base64_codec.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_11.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp861.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_greek.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/charmap.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/ptcp154.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp424.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_9.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso2022_kr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_6.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_iceland.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso2022_jp_2004.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/utf_8_sig.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp874.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_centeuro.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso2022_jp.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/zlib_codec.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_greek.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_7.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/punycode.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/utf_16.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/gb18030.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp865.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/shift_jis.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp855.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/string_escape.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_cyrillic.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/unicode_internal.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1250.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/quopri_codec.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp855.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/big5hkscs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/big5.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp850.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso2022_jp_1.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_latin2.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso2022_jp_2.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_arabic.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/hp_roman8.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_7.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp852.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_turkish.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp860.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/ptcp154.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp424.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1255.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/euc_jisx0213.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/bz2_codec.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp857.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp866.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp949.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_croatian.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp037.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp737.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/utf_32_be.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/utf_32_le.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_farsi.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp875.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp775.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso2022_jp_1.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp860.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1258.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1252.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/euc_kr.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/utf_8.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/euc_kr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/rot_13.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/rot_13.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/string_escape.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1251.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp737.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/euc_jp.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/shift_jis.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_2.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/shift_jisx0213.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/big5.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_4.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp775.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/euc_jis_2004.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp862.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/utf_7.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/euc_jisx0213.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/palmos.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/aliases.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_arabic.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/latin_1.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/utf_32_be.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp862.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_centeuro.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp500.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso2022_jp_ext.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_14.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp866.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/bz2_codec.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/undefined.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/unicode_internal.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp437.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_1.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/utf_8_sig.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp857.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp1006.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_8.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/idna.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp720.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/mac_roman.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_14.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp437.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp863.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_16.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/cp850.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/encodings/iso8859_4.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/FormatParagraph.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/RemoteObjectBrowser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/MultiCall.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/GrepDialog.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Debugger.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/HyperParser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ColorDelegator.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/OutputWindow.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/configDialog.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/configSectionNameDialog.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/SearchDialogBase.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/dynOptionMenuWidget.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ParenMatch.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ObjectBrowser.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/IOBinding.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ObjectBrowser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ZoomHeight.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/CodeContext.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Bindings.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/PathBrowser.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ParenMatch.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/WindowList.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Percolator.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/FileList.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/IOBinding.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/EditorWindow.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/AutoExpand.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Debugger.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ReplaceDialog.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/SearchDialog.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/configHandler.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/MultiStatusBar.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/config-main.def
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/CallTipWindow.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/testcode.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/MultiCall.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idlever.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/WidgetRedirector.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/RemoteDebugger.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/TreeWidget.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ReplaceDialog.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/README.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ClassBrowser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/textView.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/NEWS.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/PyShell.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/SearchDialog.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idlever.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/PathBrowser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ScrolledList.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/FormatParagraph.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/aboutDialog.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/configDialog.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/PyParse.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/keybindingDialog.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Delegator.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/IdleHistory.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/help.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/configHelpSourceEdit.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/dynOptionMenuWidget.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ScriptBinding.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/PyShell.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/configSectionNameDialog.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/tabbedpages.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Delegator.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ZoomHeight.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ScriptBinding.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/WidgetRedirector.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/OutputWindow.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/TODO.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/UndoDelegator.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/rpc.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/SearchEngine.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle.bat
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ToolTip.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/macosxSupport.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/textView.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/FileList.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/config-highlight.def
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/PyParse.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle.pyw
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/RstripExtension.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/CREDITS.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/config-extensions.def
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Percolator.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/EditorWindow.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/CallTips.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/run.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/HISTORY.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/AutoComplete.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/RstripExtension.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ColorDelegator.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/rpc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/AutoCompleteWindow.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/AutoCompleteWindow.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/CallTipWindow.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/SearchDialogBase.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/StackViewer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/extend.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/ChangeLog
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/config-keys.def
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/TreeWidget.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/configHelpSourceEdit.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Icons/plusnode.gif
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Icons/idle.icns
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Icons/openfolder.gif
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Icons/idle_16.png
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Icons/idle_32.gif
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Icons/minusnode.gif
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Icons/folder.gif
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Icons/idle_48.gif
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Icons/idle_32.png
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Icons/idle_16.gif
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Icons/idle_48.png
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Icons/tk.gif
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Icons/idle.ico
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/Icons/python.gif
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_widgetredir.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/htest.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_formatparagraph.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_searchdialogbase.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_delegator.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_idlehistory.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_grep.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_warning.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_searchengine.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_configdialog.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_rstrip.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_warning.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/README.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/mock_idle.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_autoexpand.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_calltips.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_textview.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/htest.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_config_name.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_text.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/mock_idle.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_pathbrowser.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_pathbrowser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_autocomplete.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_autocomplete.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_text.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/mock_tk.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_hyperparser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_idlehistory.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_parenmatch.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_autoexpand.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_config_name.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_formatparagraph.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_textview.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_searchengine.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/mock_tk.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_configdialog.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/idlelib/idle_test/test_rstrip.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/forking.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/process.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/heap.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/synchronize.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/reduction.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/heap.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/managers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/queues.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/util.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/pool.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/connection.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/sharedctypes.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/reduction.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/forking.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/sharedctypes.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/dummy/connection.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/multiprocessing/dummy/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_import.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/regrtest.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_int.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pep263.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_imageop.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_contains.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_xrange.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_old_mailbox.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_buffer.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_unicode_file.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_set.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_future_builtins.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/re_tests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_wait3.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_wait4.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_xdrlib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_SimpleHTTPServer.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_poplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ttk_guionly.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_opcodes.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_trace.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_descrtut.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_weakset.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/doctest_aliases.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_defaultdict.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_openpty.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_normalization.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/sample_doctest_no_docstrings.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/threaded_import_hangers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_logging.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_iter.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_syntax.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_largefile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_xmlrpc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_select.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_exceptions.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/outstanding_bugs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_threaded_import.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_strftime.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_itertools.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_aifc.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/pydoc_mod.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_warnings.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_mutants.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_print.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_descr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/list_tests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_anydbm.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_symtable.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_future3.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_future1.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pep247.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_slice.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bytes.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_epoll.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ttk_textonly.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/ssl_cert.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dis.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_nntplib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/testall.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/exception_hierarchy.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_univnewlines2k.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sax.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/ssl_key.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_funcattrs.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_idle.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_functools.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/reperf.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codeop.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_unary.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_argparse.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_copy.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dict.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_list.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_poll.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/sha256.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/infinite_reload.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/inspect_fodder.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_doctest.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_mutex.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_future.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_datetime.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_unittest.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_popen2.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_calendar.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_asynchat.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dictviews.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/pystone.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_abc.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_compare.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_list.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test___future__.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_structmembers.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cmd_line.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_strptime.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_SimpleHTTPServer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_genericpath.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_macos.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_unicodedata.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/_mock_backport.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_anydbm.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_lib2to3.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pydoc.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_trace.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_telnetlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/time_hashlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_email_codecs.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ensurepip.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/badsyntax_nocaret.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_glob.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sysconfig.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_thread.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_docxmlrpc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_iter.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_warnings.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_memoryview.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_userlist.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bastion.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pkgutil.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_binhex.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_generators.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_struct.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_memoryio.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_file.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_collections.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sets.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_audioop.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_urllib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_new.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_hash.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_rlcompleter.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_uuid.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/dh512.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_types.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/pydocfodder.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_module.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/_mock_backport.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ascii_formatd.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_shelve.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_parser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_fork1.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bisect.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_socket.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_genexps.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/sample_doctest_no_docstrings.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/badsyntax_future8.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dl.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bigaddrspace.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_binascii.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_zlib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_operator.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_int_literal.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_contextlib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_tools.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_complex_args.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_compileall.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_coercion.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cfgparser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_getopt.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_decorators.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_float.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_richcmp.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bz2.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cl.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_types.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecencodings_cn.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_class.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_py_compile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_generators.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/lock_tests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_httplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_multiprocessing.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_os.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_xml_etree_c.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_tempfile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_tarfile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/fork_wait.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_wsgiref.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ntpath.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_urllib2net.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sys_settrace.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_complex.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_htmlparser.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cookie.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_strop.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ucn.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_module.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bisect.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_exception_variations.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pickletools.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pkgimport.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_commands.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_imaplib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pwd.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_multibytecodec.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cpickle.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/warning_tests.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_future4.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_string.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_whichdb.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_urllibnet.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_marshal.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_mimetypes.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_mimetools.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cgi.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_xml_etree.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_json.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/sortperf.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_urllibnet.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/badkey.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_grp.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pty.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/double_const.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_fileinput.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_abc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_property.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/script_helper.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/selfsigned_pythontestdotnet.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/pickletester.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_urlparse.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_str.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_difflib_expect.html
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_threading_local.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_heapq.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_py3kwarn.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pep292.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/ssl_key.passwd.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_zipfile64.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecmaps_cn.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_functools.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cmath_testcases.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_zlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pdb.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_eof.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pipes.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ssl.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_gettext.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_coding.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_startfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_threadedtempfile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecmaps_cn.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_re.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cmd_line_script.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_rfc822.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_shlex.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_winsound.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_imgfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ossaudiodev.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sys_setprofile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_call.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_csv.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/audiotests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_softspace.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_index.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_hashlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pep277.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecmaps_hk.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/symlink_support.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_abstract_numbers.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_kqueue.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_weakref.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sha.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_doctest3.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_descrtut.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_hmac.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_errno.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pow.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_linecache.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_modulefinder.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_gc.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_random.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/bad_coding.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_spwd.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_optparse.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_select.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dbm.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/pyclbr_input.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ioctl.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_deque.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/mapping_tests.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pickletools.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/testtar.tar
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/seq_tests.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_structseq.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecencodings_iso2022.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/greyrgb.uue
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_grammar.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_tuple.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/badsyntax_future5.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test___all__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_unpack.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_unicode.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_thread.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_future2.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_textwrap.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_macpath.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_traceback.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_getargs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/badsyntax_future9.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/tokenize_tests.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_spwd.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/win_console_handler.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_mailbox.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_httpservers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecmaps_hk.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_frozen.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_gc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bsddb185.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_enumerate.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_inspect.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test__locale.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pyexpat.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_stat.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/relimport.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_queue.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_setcomps.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_random.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_posix.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_future1.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pow.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bufio.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pprint.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_fcntl.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_fnmatch.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_urllib2net.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_plistlib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_quopri.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_email_renamed.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_imaplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_code.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecencodings_kr.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/buffer_tests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_strtod.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dircache.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/nullbytecert.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sgmllib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_tk.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_plistlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_userstring.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_doctest.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_tk.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_charmapcodec.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_syntax.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pep292.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_copy_reg.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_nntplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_locale.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/gdb_sample.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_kqueue.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bool.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_stringprep.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_winreg.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cmath.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_macos.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_binop.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_typechecks.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_shlex.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/keycert4.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_contextlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_abstract_numbers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_zipfile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_int_literal.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/gdb_sample.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_distutils.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pstats.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_wave.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/badsyntax_future7.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pep352.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_iterlen.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_msilib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_socketserver.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_longexp.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_getargs2.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_support.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sys.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_macostools.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_fileio.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_threading.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_io.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_gzip.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_threadsignals.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_doctest2.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_iterlen.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dictcomps.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/mapping_tests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_importlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_xdrlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sunau.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_future5.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test__osx_support.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bsddb3.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sys.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/bad_coding3.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecencodings_hk.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_threaded_import.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_site.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_zipimport_support.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dict.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/curses_tests.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_extcall.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pep352.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sysconfig.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_imghdr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_md5.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/xmltests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_openpty.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/sample_doctest.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_atexit.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_richcmp.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dumbdbm.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_al.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_unicode.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_strtod.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_array.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_tarfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_future3.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_funcattrs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_signal.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_hotshot.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/tf_inherit_check.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/string_tests.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_isinstance.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cfgparser.1
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_copy_reg.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_univnewlines.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/sgml_input.html
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_gl.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dumbdbm.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_file_eintr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sunaudiodev.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_mhlib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pickle.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_zipimport.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecencodings_jp.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/Sine-1000Hz-300ms.aif
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ast.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codeccallbacks.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/185test.db
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_zipfile64.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_MimeWriter.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_contains.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_complex_args.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_weakset.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_transformer.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ssl.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/mp_fork_bomb.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_mmap.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_compiler.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dl.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_StringIO.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_gdbm.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/revocation.crl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_undocumented_details.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_heapq.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/curses_tests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_repr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_crypt.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_gdb.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_wait3.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/inspect_fodder.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_scriptpackages.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_defaultdict.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_quopri.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_capi.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/randv3.pck
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dummy_threading.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_commands.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_fractions.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sort.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cmd_line.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_builtin.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ioctl.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pyexpat.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_shutil.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_difflib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sundry.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cd.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/regrtest.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_htmllib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_profile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_json.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/testcodec.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_compile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_macurl2path.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_userdict.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_idle.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_peepholer.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_xpickle.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pickle.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_fpformat.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_math.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_StringIO.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/bad_coding2.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ftplib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_math.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_filecmp.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/infinite_reload.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_userdict.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/keycert.passwd.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_format.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecencodings_tw.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/math_testcases.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bsddb.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_tempfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_gl.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pydoc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bytes.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_robotparser.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ossaudiodev.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_time.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_fork1.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/badsyntax_future4.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_operator.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_subprocess.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_difflib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecmaps_kr.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_import.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cookielib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_multibytecodec_support.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_winsound.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/ssl_servers.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_decimal.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_with.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_colorsys.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sunau.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecmaps_tw.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_itertools.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_zipfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_popen.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/inspect_fodder2.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_grp.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bsddb3.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/keycert3.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_long.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/re_tests.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_timeout.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_shutil.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_base64.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_fractions.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_applesingle.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/script_helper.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ctypes.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/badsyntax_future6.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_file2k.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_multibytecodec.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_argparse.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cookie.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_wave.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/testimg.uue
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_hmac.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_netrc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_augassign.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_runpy.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bigmem.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pep263.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_unicode_file.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/profilee.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_crypt.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_aepack.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/floating_points.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sqlite.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_unary.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_macpath.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_strftime.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dummy_thread.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_email.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_normalization.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_imp.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/doctest_aliases.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_importhooks.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_grammar.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ctypes.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_mutants.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_readline.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_compiler.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pyclbr.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_uu.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_long_future.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_wait4.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/nokia.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/inspect_fodder2.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cookielib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cmd.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sunaudiodev.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_deque.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_nis.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/randv2_32.pck
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_nis.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_future5.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cprofile.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_tokenize.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/relimport.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pkg.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pep277.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_old_mailbox.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_colorsys.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/symlink_support.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_xpickle.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_whichdb.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/make_ssl_certs.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_imp.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ast.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_decimal.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_tcl.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/badsyntax_future3.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_int.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_inspect.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_weakref.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_linecache.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_tuple.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_str.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_filecmp.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/ssl_servers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_linuxaudiodev.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/sample_doctest_no_doctests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_smtpnet.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_peepholer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codeop.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cmath.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_email_codecs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bastion.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_calendar.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_resource.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/ieee754.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_asyncore.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_glob.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sundry.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_posixpath.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sgmllib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dummy_thread.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_py3kwarn.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/nullcert.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/keycert.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ensurepip.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_threading_local.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_multifile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/list_tests.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_genexps.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_unittest.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_decorators.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_asynchat.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_mimetools.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_macostools.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_posix.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/testcodec.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_asyncore.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/formatfloat_testcases.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_complex.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_global.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_imageop.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/zipdir.zip
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_os.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_popen2.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/pyclbr_input.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dictcomps.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/seq_tests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_copy.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_robotparser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/https_svn_python_org_root.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ttk_guionly.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/autotest.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_curses.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_collections.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/tf_inherit_check.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_new.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_scope.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/randv2_64.pck
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_compare.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_transformer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pwd.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_socketserver.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_future.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/pystone.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_platform.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/testimgr.uue
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_py_compile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_index.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_longexp.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sha.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cprofile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_minidom.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/empty.vbs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_posixpath.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_aepack.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_class.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ftplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_aifc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_strptime.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codeccallbacks.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/testall.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/keycert2.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_tokenize.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cgi.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_hash.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_ntpath.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/pydoc_mod.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_multiprocessing.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/warning_tests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/audiotest.au
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_fpformat.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_rlcompleter.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/pickletester.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sax.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_scope.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_cmd.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/make_ssl_certs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pipes.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecmaps_jp.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pty.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/outstanding_bugs.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_tools.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_lib2to3.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_file2k.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_unpack.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_doctest2.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecencodings_cn.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/testrgb.uue
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_urllib2.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_curses.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_wsgiref.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_set.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_format.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_urllib2.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecmaps_jp.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_shelve.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dummy_threading.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecmaps_kr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_xml_etree.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/pycacert.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_coercion.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_smtplib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_smtplib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_fcntl.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecencodings_jp.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_descr.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_email_renamed.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_xmlrpc.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_minidom.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/fork_wait.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_urllib2_localnet.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_gdbm.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pep247.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bsddb.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_unicodedata.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/win_console_handler.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_structmembers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_dis.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_email.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_macurl2path.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_errno.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_resource.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pprint.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_slice.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sqlite.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_sets.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/wrongcert.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_pyclbr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_xmllib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_mutex.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_memoryview.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_coding.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_gdb.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_binascii.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_htmlparser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/badcert.pem
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bsddb185.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_fnmatch.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_doctest2.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_marshal.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_frozen.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/string_tests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_urllib2_localnet.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_file.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test___future__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_threadedtempfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/check_soundcard.vbs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_doctest4.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_buffer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_bufio.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/test_codecencodings_kr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/capath/6e88d7b8.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/capath/5ed36f99.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/capath/4e1295a3.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/capath/99d0fa06.0
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ln.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/nexttoward.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddRemainderNear.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqNextPlus.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/logb.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/nextplus.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddAbs.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/shift.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/decSingle.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/rescale.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqCopyNegate.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddCompare.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/abs.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddEncode.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddMultiply.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/copyabs.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddNextToward.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqCanonical.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqAdd.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/invert.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddXor.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqPlus.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqFMA.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/or.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqNextMinus.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqAnd.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/inexact.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/remainderNear.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/rotate.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/copysign.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/multiply.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dsEncode.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqCopy.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/xor.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqInvert.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/divideint.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/compare.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqMax.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddNextMinus.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddCompareSig.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/remainder.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddSameQuantum.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddMax.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddCopy.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddToIntegral.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqScaleB.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dsBase.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqOr.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqNextToward.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddMinus.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqLogB.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqMinMag.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/tointegral.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqDivide.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/class.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqClass.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqBase.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddCopyAbs.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/maxmag.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqMaxMag.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqCompareSig.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqToIntegral.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqEncode.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddCanonical.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqQuantize.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqReduce.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqXor.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/quantize.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/reduce.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/testall.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/minmag.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddPlus.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddOr.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/nextminus.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/tointegralx.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/copy.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/exp.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/scaleb.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddFMA.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/min.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddShift.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/minus.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddNextPlus.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqAbs.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/power.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddAnd.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddScaleB.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/divide.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddCompareTotal.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddMin.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/copynegate.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddClass.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddAdd.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqMin.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqCompare.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/comparetotmag.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddRemainder.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/clamp.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/randomBound32.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqRotate.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddInvert.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/randoms.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqShift.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/plus.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddMaxMag.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddCompareTotalMag.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqSameQuantum.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/base.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddRotate.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddMinMag.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqSubtract.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/comparetotal.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/add.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqCopyAbs.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/extra.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/squareroot.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqCompareTotalMag.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/and.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqDivideInt.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqCompareTotal.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqRemainderNear.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/decQuad.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqMinus.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/log10.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/samequantum.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqRemainder.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddLogB.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/rounding.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddDivide.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqCopySign.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/dqMultiply.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddCopySign.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddDivideInt.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddSubtract.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/max.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddReduce.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/subtract.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddQuantize.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddCopyNegate.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/decDouble.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/powersqrt.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/ddBase.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/decimaltestdata/fma.decTest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/subprocessdata/sigchild_ignore.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/subprocessdata/sigchild_ignore.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/data/README
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/tracedmodules/testmod.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/tracedmodules/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/audiodata/pluck-pcm32.au
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/audiodata/pluck-ulaw.aifc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/audiodata/pluck-pcm8.wav
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/audiodata/pluck-pcm16.au
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/audiodata/pluck-ulaw.au
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/audiodata/pluck-pcm24.aiff
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/audiodata/pluck-pcm16.wav
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/audiodata/pluck-pcm8.au
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/audiodata/pluck-pcm32.wav
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/audiodata/pluck-pcm8.aiff
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/audiodata/pluck-pcm32.aiff
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/audiodata/pluck-pcm16.aiff
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/audiodata/pluck-pcm24.wav
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/imghdrdata/python.pgm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/imghdrdata/python.pbm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/imghdrdata/python.ppm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/imghdrdata/python.bmp
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/imghdrdata/python.png
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/imghdrdata/python.sgi
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/imghdrdata/python.ras
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/imghdrdata/python.tiff
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/imghdrdata/python.xbm
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/imghdrdata/python.jpg
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/imghdrdata/python.gif
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/euc_kr-utf8.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/johab.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/euc_jisx0213.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/euc_jp-utf8.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/big5-utf8.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/iso2022_kr-utf8.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/big5.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/shift_jis-utf8.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/gb18030.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/gb18030-utf8.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/shift_jisx0213-utf8.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/hz-utf8.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/iso2022_jp-utf8.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/hz.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/euc_jp.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/cp949-utf8.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/shift_jis.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/gb2312.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/gbk.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/big5hkscs.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/big5hkscs-utf8.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/gbk-utf8.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/iso2022_jp.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/gb2312-utf8.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/cp949.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/euc_kr.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/euc_jisx0213-utf8.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/shift_jisx0213.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/iso2022_kr.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/cjkencodings/johab-utf8.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/xmltestdata/simple-ns.xml
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/xmltestdata/simple.xml
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/xmltestdata/test.xml
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/test/xmltestdata/test.xml.out
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/hotshot/stats.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/hotshot/stones.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/hotshot/log.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/hotshot/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/hotshot/stones.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/wsgiref/handlers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/wsgiref/validate.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/wsgiref/headers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/wsgiref/util.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/wsgiref/util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/wsgiref/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/wsgiref/simple_server.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/decoder.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/encoder.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tool.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/scanner.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/decoder.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/scanner.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_separators.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_dump.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_recursion.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_float.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_pass3.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_pass2.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_unicode.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_pass1.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_encode_basestring_ascii.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_encode_basestring_ascii.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_decode.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_indent.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_unicode.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_pass3.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_scanstring.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_speedups.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_check_circular.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_default.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_indent.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_tool.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_fail.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_scanstring.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_speedups.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_fail.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_pass1.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/json/tests/test_decode.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/btm_matcher.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/patcomp.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/__main__.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/btm_matcher.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/PatternGrammar2.7.9.final.0.pickle
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/Grammar.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/refactor.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/main.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixer_util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixer_base.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/PatternGrammar.txt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/refactor.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixer_base.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/pytree.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/btm_utils.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/pygram.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/__main__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/pytree.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/Grammar2.7.9.final.0.pickle
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/test_all_fixers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/test_util.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/test_refactor.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/test_refactor.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/test_parser.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/test_main.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/test_fixers.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/test_util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/test_pytree.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/support.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/test_fixers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/pytree_idempotency.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/README
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/py3_test_grammar.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/bom.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/py2_test_grammar.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/different_encoding.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/false_encoding.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/infinite_recursion.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/crlf.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/fixers/bad_order.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/fixers/no_fixer_cls.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/fixers/parrot_example.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/fixers/myfixes/fix_explicit.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/fixers/myfixes/fix_last.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/fixers/myfixes/fix_first.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/fixers/myfixes/fix_parrot.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/fixers/myfixes/fix_preorder.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/tests/data/fixers/myfixes/__init__.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/pgen2/driver.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/pgen2/grammar.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/pgen2/tokenize.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/pgen2/conv.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/pgen2/literals.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/pgen2/token.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/pgen2/parse.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/pgen2/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/pgen2/pgen.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/pgen2/literals.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/pgen2/token.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_asserts.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_throw.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_funcattrs.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_callable.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_itertools_imports.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_types.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_ne.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_operator.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_imports2.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_sys_exc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_except.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_imports.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_tuple_params.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_types.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_execfile.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_repr.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_urllib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_exitfunc.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_raise.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_unicode.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_has_key.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_long.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_paren.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_print.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_import.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_renames.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_tuple_params.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_filter.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_exec.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_standarderror.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_buffer.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_next.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_itertools_imports.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_imports.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_xreadlines.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_basestring.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_xreadlines.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_xrange.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_methodattrs.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_getcwdu.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_repr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_nonzero.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_itertools.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_metaclass.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_set_literal.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_input.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_methodattrs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_except.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_dict.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_map.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_future.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_raw_input.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_set_literal.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_funcattrs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_map.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_intern.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_idioms.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_ws_comma.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_zip.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_throw.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_exitfunc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_ws_comma.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_operator.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_import.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_numliterals.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_reduce.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_buffer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_raw_input.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_callable.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_isinstance.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_idioms.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_apply.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_input.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_isinstance.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_zip.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_numliterals.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_nonzero.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_exec.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_imports2.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_future.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_asserts.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/lib2to3/fixes/fix_has_key.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/_endian.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/wintypes.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/wintypes.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/util.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/macholib/fetch_macholib.bat
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/macholib/dylib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/macholib/framework.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/macholib/dyld.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/macholib/README.ctypes
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/macholib/dylib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/macholib/dyld.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/macholib/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_frombuffer.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_prototypes.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_sizes.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_buffers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_pointers.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_structures.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_arrays.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_simplesubclasses.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/runtests.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_internals.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_returnfuncptrs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_slicing.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_macholib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_delattr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_refcounts.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_callbacks.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_functions.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_as_parameter.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_funcptr.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_values.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_cfuncs.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_cast.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_find.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_loading.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_as_parameter.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_wintypes.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_struct_fields.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_python_api.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_errno.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_keeprefs.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_unicode.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_win32.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_frombuffer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_init.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_prototypes.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_unaligned_structures.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_varsize_struct.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_libc.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_byteswap.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_strings.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_sizes.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_arrays.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_memfunctions.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_unicode.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_keeprefs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_win32.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_random_things.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_pickling.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_pickling.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_pointers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_functions.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_bitfields.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_repr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/runtests.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_init.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_libc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_pep3118.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_array_in_pointer.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_strings.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_parameters.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_checkretval.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_numbers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_struct_fields.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_values.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_incomplete.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_anon.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_cast.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_objects.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_stringptr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_pep3118.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_cfuncs.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_incomplete.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_internals.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_callbacks.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_python_api.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_funcptr.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/ctypes/test/test_array_in_pointer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/unixccompiler.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/cygwinccompiler.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/README
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/text_file.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/cmd.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/dir_util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/dep_util.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/debug.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/version.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/sysconfig.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/ccompiler.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/bcppcompiler.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/extension.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/core.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/config.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/fancy_getopt.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/filelist.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/emxccompiler.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/dist.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/errors.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/file_util.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/dep_util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/log.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/archive_util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/util.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/cmd.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/filelist.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/spawn.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/version.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/sysconfig.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/spawn.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/msvccompiler.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/ccompiler.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/file_util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/versionpredicate.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/msvc9compiler.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/msvc9compiler.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/text_file.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/fancy_getopt.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/errors.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/setuptools_extension.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_upload.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_dep_util.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_msvc9compiler.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_dir_util.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_install.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_install_scripts.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_bdist_rpm.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_util.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_bdist_rpm.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/setuptools_extension.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_versionpredicate.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_bdist.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_install_lib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_sysconfig.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_spawn.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/setuptools_build_ext.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_build_clib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_version.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_bdist_dumb.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_register.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_build_ext.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_bdist_msi.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_bdist_dumb.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_dep_util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_archive_util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_clean.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_unixccompiler.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_install_headers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_build_scripts.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_versionpredicate.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_upload.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_build_ext.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_install_scripts.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_sysconfig.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_text_file.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/xxmodule.c
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_install_data.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/Setup.sample
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_sdist.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_build_py.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/support.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_sdist.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_config_cmd.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_file_util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_bdist_msi.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_filelist.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_ccompiler.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_dist.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_cmd.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_version.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_install_data.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_core.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_register.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_bdist_wininst.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_dir_util.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_config.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_cmd.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_check.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_config.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_build.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/tests/test_build.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/upload.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/sdist.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/build_py.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/bdist_rpm.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/install_egg_info.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/wininst-8.0.exe
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/command_template
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/install.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/config.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/build_scripts.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/build.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/install_lib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/build_ext.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/bdist.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/install_scripts.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/install.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/install_lib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/bdist_rpm.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/build_clib.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/wininst-6.0.exe
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/install_headers.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/bdist_wininst.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/bdist_msi.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/wininst-9.0-amd64.exe
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/bdist_msi.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/build_scripts.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/clean.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/bdist_dumb.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/register.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/build.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/install_data.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/build_clib.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/check.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/wininst-7.1.exe
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/build_ext.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/register.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/install_data.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/wininst-9.0.exe
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/check.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/distutils/command/install_egg_info.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compiler/misc.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compiler/pyassem.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compiler/visitor.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compiler/syntax.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compiler/future.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compiler/ast.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compiler/transformer.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compiler/pycodegen.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compiler/future.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compiler/visitor.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compiler/consts.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compiler/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compiler/symbols.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compiler/pyassem.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/compiler/symbols.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/curses/has_key.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/curses/ascii.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/curses/panel.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/curses/wrapper.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/curses/textpad.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/curses/__init__.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/curses/has_key.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/plat-linux2/CDROM.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/plat-linux2/IN.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/plat-linux2/IN.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/plat-linux2/DLFCN.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/plat-linux2/TYPES.py
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/plat-linux2/regen
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/lib/python2.7/plat-linux2/TYPES.pyc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/setobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/import.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pystrcmp.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pyarena.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/iterobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pycapsule.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/Python.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/classobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pymem.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/bytes_methods.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pydebug.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/tupleobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/symtable.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/longintrepr.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pymactoolbox.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pyexpat.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/ceval.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pymacconfig.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/asdl.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/structseq.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pymath.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/opcode.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/fileobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pyfpe.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pyerrors.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/py_curses.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/weakrefobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/bufferobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pystate.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/codecs.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/eval.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/traceback.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/structmember.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/floatobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/dtoa.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/warnings.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/cStringIO.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/stringobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/cobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/timefuncs.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/enumobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/parsetok.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/datetime.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/complexobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/marshal.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/grammar.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/bitset.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/ast.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/modsupport.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/objimpl.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/errcode.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/boolobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/compile.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/methodobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pyport.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/node.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/sysmodule.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/code.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pgen.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/unicodeobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/osdefs.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/genobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/intobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pyconfig.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/abstract.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/Python-ast.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pgenheaders.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/memoryobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/patchlevel.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/rangeobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/longobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/funcobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pyctype.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/cellobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/dictobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/graminit.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/object.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pystrtod.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/token.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/bytesobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/listobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/metagrammar.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pygetopt.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pythonrun.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/bytearrayobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/descrobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/sliceobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/moduleobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/pythread.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/ucnhash.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/intrcheck.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/usr/include/python2.7/frameobject.h
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-unixadmin
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-xml
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-dev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-distutils
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-audio
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-syslog
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-re
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-mmap
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-multiprocessing
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-compiler
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-tkinter
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-profile
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-tests
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-pprint
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-html
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-unittest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-image
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-elementtree
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-shell
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-json
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-numbers
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-xmlrpc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-compression
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-distutils-staticdev
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-crypt
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-stringold
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-argparse
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-mailbox
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-hotshot
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-mime
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-db
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-datetime
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-debugger
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-fcntl
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-lang
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-idle
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-email
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-resource
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-subprocess
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-logging
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-threading
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-robotparser
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-terminal
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-pydoc
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-difflib
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-importlib
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-curses
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-2to3
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-math
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-core
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-pickle
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-contextlib
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-smtpd
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-bsddb
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-netserver
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-sqlite3
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-doctest
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-pkgutil
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-sqlite3-tests
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-textutils
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-zlib
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-ctypes
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-codecs
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-netclient
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-readline
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-io
 /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr/sysroot-providers/python-gdbm
Please verify which recipe should provide the above files.
The build has stopped as continuing in this scenario WILL break things, if not now, possibly in the future (we've seen builds fail several months later). If the system knew how to recover from this automatically it would however there are several different scenarios which can result in this and we don't know which one this is. It may be you have switched providers of something like virtual/kernel (e.g. from linux-yocto to linux-yocto-dev), in that case you need to execute the clean task for both recipes and it will resolve this error. It may be you changed DISTRO_FEATURES from systemd to udev or vice versa. Cleaning those recipes should again resolve this error however switching DISTRO_FEATURES on an existing build directory is not supported, you should really clean out tmp and rebuild (reusing sstate should be safe). It could be the overlapping files detected are harmless in which case adding them to SSTATE_DUPWHITELIST may be the correct solution. It could also be your build is including two different conflicting versions of things (e.g. bluez 4 and bluez 5 and the correct solution for that would be to resolve the conflict. If in doubt, please ask on the mailing list, sharing the error and filelist above.
ERROR: If the above message is too much, the simpler version is you're advised to wipe out tmp and rebuild (reusing sstate is fine). That will likely fix things in most (but not all) cases.
WARNING: Logfile for failed setscene task is /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/python/2.7.9-r1/temp/log.do_populate_sysroot_setscene.5388
WARNING: Setscene task 397 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-devtools/python/python_2.7.9.bb, do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
NOTE: Executing RunQueue Tasks
ERROR: oe_runmake failed
ERROR: Function failed: do_install (log file is located at /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/util-linux/2.26.2-r0/temp/log.do_install.17441)
ERROR: Logfile of failure stored in: /home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/util-linux/2.26.2-r0/temp/log.do_install.17441
Log data follows:
| DEBUG: SITE files ['endian-little', 'bit-32', 'arm-common', 'arm-32', 'common-linux', 'common-glibc', 'arm-linux', 'arm-linux-gnueabi', 'common']
| DEBUG: Executing shell function do_install
| NOTE: make -j 4 ARCH=arm CPU= CPUOPT= OPT= -O2 -pipe -g -feliminate-unused-debug-types CC=arm-fsl-linux-gnueabi-gcc  -march=armv7-a -mfloat-abi=hard -mfpu=neon -mtune=cortex-a7 --sysroot=/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr LD=arm-fsl-linux-gnueabi-ld --sysroot=/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/sysroots/ls1021atwr  LDFLAGS=-Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed DESTDIR=/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/util-linux/2.26.2-r0/image install
| make: *** No rule to make target `/home/youyou/work/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/util-linux/2.26.2-r0/util-linux-2.26.2/Makefile.am', needed by `/home/youyou/work/QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/work/cortexa7hf-vfp-neon-fsl-linux-gnueabi/util-linux/2.26.2-r0/util-linux-2.26.2/Makefile.in'.  Stop.
| WARNING: exit code 1 from a shell command.
ERROR: Task 854 (/home/youyou/work/temp/qoriqLs1021A/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-core/util-linux/util-linux_2.26.2.bb, do_install) failed with exit code '1'
NOTE: Tasks Summary: Attempted 592 tasks of which 588 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 48 ERROR messages shown, returning a non-zero exit code.
Pavel
It looks like that there is problem concerning to PATH for SDK on your PC.
If you want to build SDK u-boot or kernel, use FAQ from SDK 2.0-1703 documentation:
http://www.nxp.com/assets/documents/data/en/supporting-information/QORIQ-SDK-2.0-IC-REV0.pdf
Find the following:
How do I use standalone toolchain to build kernel?
Install SDK to different folder if a few SDK is needed on your PC.
Pavel Chubakov
youyou
Thank you very much for your help,because I was busy with something ,so there is no confirmation of your response in time,I  use standalone toolchain,than can compile through,but I have some other problems,I'll debug later when I'm free.Thanks!
