Windows 7 driver for Cable, USB Type-A to DB9F
已解决
跳至解决方案
2,400 次查看
bharat_chaudhar
I have LS1028ARDB.
The box came with a "Cable, USB Type-A to DB9F (Windows 10 support), 1 m" as documented in Getting Started with LS1028ARDB | NXP
I'm unable to get the driver for windows 7. Is there link available for this?
Bharat
1 解答
2,334 次查看
Pavel
Usually these cables use the PL2303 chip or CP210x or chip from FTDI.
See the following page about drivers for the PL2303:
http://www.prolific.com.tw/US/ShowProduct.aspx?p_id=225&pcid=41
See the following page about driver for CP210x:
https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers
See the following page about driver for FTDI:
https://www.ftdichip.com/Drivers/VCP.htm
Pavel Chubakov
在原帖中查看解决方案
2 回复数
2,335 次查看
Pavel
Pavel Chubakov
2,334 次查看
bharat_chaudhar
Thanks it turned out to be PL2303.
I connected the converter to a Linux machine that recognized it as Prolific PL2303.
I then refereed your reply for link to the driver.
Bharat
