No such file or directory
dongyeonkim01
we are following Trusted Excution(OP-TEE)  section on the LSDKUG_REV20.04 document
We checked whether the OP-TEE kernel driver was successfully initialized and we got this result,
so, I tried to run the tee-supplicant file, but it running failed..
and I can't try xtest to
NXP board : LX2160ardb
yipingwang
1. In configs/build_lsdk.cfg
CONFIG_APP_OPTEE=y
2. Build optee-os, optee-client and optee-test
$ flex-builder -c optee -m lx2160ardb
3. Rebuild atf with optee-os included in fip.bin
flex-builder -c atf -m lx2160ardb -b xspi
4. Please reprogram build/firmware/atf/lx2160ardb/fip_uboot.bin on the target board.
5. Merge optee-client and optee-test into rootfs filesystem.
$ flex-builder -i merge-component -a arm64
$ flex-builder -i packrfs
dongyeonkim01
hello
thank you for your replying,
I tried build new image include 'CONFIG_APP_OPTEE=y' option and build success,
I tried update image to NXP board and i can get this message
but still can't run 'xtest' and './tee-supplicant'
so, I tried next step,
 i got fail..
* ps
What message will be printed when 'te-supplicant' is run normally?
yipingwang
I didn't reproduce your problem when executing the following command.
$ flex-builder -c optee_test -m lx2160ardb
Which version LSDK are you using?
Please use LSDK 2012 or LSDK 2004.
dongyeonkim01
Hi, thank you for your reply
but i can't solve issues,
I used LSDK 2004.
I try this command
and i got this result
yipingwang
Are you using Ubuntu 18.04 to build LSDK 2004?
dongyeonkim01
thanks your reply
I solved .. issue
Build tool was an issue.
thank you for your help
