Header manipulation on P2041RDB-PB using XML files
shashankreddyvu
hi,
I am trying to update or modify the packet header, using code warrior i generated the pcd xml file and tried to apply using fmc tool it is generating following errors,
Warning: Unknown attribute 'header' in 'action' element - line 245
Warning: Unknown attribute 'size' in 'fieldref' element - line 273
Warning: Unknown attribute 'offset' in 'fieldref' element - line 273
Warning: Unexpected/ignored node - manipulations
but still i applied those pcd files and tried to run reflector and see any header is modified, but there was no modification (I tried to modify the vlanid of vlan packet)
The pcd file which got generated using codewarrior has been attached.
If i am doing header manipulation in the wrong place & wrong way please suggest me the right one.
Thanks & Regards
Shashank Reddy
Original Attachment has been moved to: fmc_pcd.xml
