PT2001 AN12336SW - Idle Diagnostics Failure
deckhardt
I was hoping my findings could help someone else developing idle diagnostics: I found that idle diagnostics were failing when using the microcode provided with the AN12336SW with the FRDMPT2001EVM  development board.
The following lines were generating software interrupts:
jocr idle_diag_fail0 _sc2v;
jocr idle_diag_fail0 _sc1s;
jocr idle_diag_fail0 _sc3s;
The interrupt was being thrown before the voltages at S_HSx and D_LSx had sufficient time to reach their stable value.
In order to give the PT2001 enough time for the capacitor to charge at S_HSx and D_LSx, I moved the "bias all on" function into the INIT PHASE of the microcode and now it successfully passes all idle tests.
ErikaC
The NXP support team appreciates your collaboration to help others.
Best regards.
