Hi everyone, I want to know how to recover the P2041RDB-PB because the u-boot on the NOR flash got accidentally erased.
Thanks in advance for your aswer
You should use Flash Programmer from CW, import P2041RDB_NOR_FLASH.xml Target Task, Add Program Verify Action, select Erase sector before program and set offset to 0xEFF80000 (last 512K of NOR).
Also, you can take a look at this thread: P1020RDB NOR FLASH PROGRAMMING
Adrian
