Efficiency of PF8200 with respect to temperature
Rohith04
Hi Team,
I need to know the power loss inside the PF8200 at different temperatures. I could see the efficiency in the datasheet, and it is tested in 25 deg. Can you help to find the power loss inside the PMIC under different temperature.
diazmarin09
Hello Rohith04,
I hope all is great with you. Thank you for using the NXP communities.
In this case I do recommend the following community post:
https://community.nxp.com/t5/Other-NXP-Products/efficiency-PF8200/td-p/1649545
Please let me know if this is useful for you.
David
diazmarin09
Hello Rohith04,
David
