About P4080 Srio NWrite and Nread
393002032
I have a P4080DS board ,I want to use SRIO Nwrite and Nread to transmit data ,I have already config the register as below:
1.LAW window as LAWBARH10\LAWBARL10\LAWAR10,
2,DMA config as channel 0
3.when I use Nwrite  to transmit data ,SRIO register goto Channel busy status all the time,but i cann't send data out.
can you tell me how to config Nwrite and Nread?
whether i can  config LAW window  at any window?
is there any other point should me take notice?
393002032
I'm able to read and write SRIO memory window,
The LAW、SRIO and DMA register areas are all same as your value,but it can't work well
ufedor
Please attach textual hexadecimal dumps of the initialized CCSR registers areas:
1) LAW: 0x00_0000 - 0x00_0FFF
2) SRIO: 0x0C_0000 - 0x0D_FFFF
3) DMA: 0x10_0000 - 0x10_1FFF
393002032
I have already initialized CCSR registers areas as:
but when i use Nwrite ,,SRIO register goto Channel busy status all the time
ufedor
To check the settings please attach textual hexadecimal dumps of the initialized CCSR registers areas:
ufedor
Are you able to read/write the SRIO memory window using core instructions or by means of a debugger?
Please attach textual hexadecimal dumps for the initialized CCSR registers areas:
393002032
my problem is still exist,can you tell me more info about how to config Nwrite and Nread?
