1. Difference between FreeMASTER and FreeMASTER
2.FreeMASTER's EULA has the sentence below.
2.1. NXP grants to you a personal, non-transferable, non-exclusive, license, under NXP’s intellectual property rights, to use and reproduce the Licensed Software solely in conjunction with the design of products using, or associated with, a NXP integrated circuit. You may not distribute or sublicense the Licensed Software to others except as expressly granted in Section 2.2 below.
If you have not purchased hardware and software from NXP
Is installing FreeMASTER also considered illegal?
Or is it freeware that is free to install and use?
