Kindly suggest me what should i do with the unused output ports of PCA9548A.
Thanks.
Even the unused channels need to be terminated with their pull-up resistors, unused channels should have the same size pull-up resistors as used for the other channels, and you also need to make sure that the unused channels are disabled, please take a look at Table 4 on page 7 of the datasheet for more details about how to do this.
http://www.nxp.com/documents/data_sheet/PCA9548A.pdf
Jose
Thanks for the update.
Kindly update me on this query.
Thanks.
