Time is not update when reboot the board
1,753件の閲覧回数
vinothkumars
Senior Contributor IV
Hi All,
I am using PCF8523 RTC Chip and also I mounted Coin Cell also. I configured Coin Cell as Standard mode and low Detection Mode (000). But, after setting the time when rebooting the time is not update.
Reference,
https://www.nxp.com/docs/en/data-sheet/PCF8523.pdf
If anyone know how to make this coin cell work when power off the board, As per datasheet I initialize control register 3 = 000. But, I not getting the time when power on the board
And we are using 3V battery and I want to know how much Voltage we got when switch OFF the board and switch ON the board?
Vinothkumar Sekar
7 返答(返信)
1,311件の閲覧回数
guoweisun
Do you mind provide your schematic?
1,311件の閲覧回数
vinothkumars
Hi when we check the battery the voltage we got in both on and off state is 0.4 volt only.
Vinothkumar Sekar
1,311件の閲覧回数
guoweisun
Do you have a discharge loop circuit of battery in your system?
Can you try to change a new battery to test?
1,311件の閲覧回数
vinothkumars
Thank you for your reply ,
I will replace and try whatever you suggest
Vinothkumar Sekar
1,311件の閲覧回数
vinothkumars
Please check previous replayed one, i attached screenshot of schematic of pcf8523
Vinothkumar Sekar
1,311件の閲覧回数
guoweisun
What's your system power voltage of RTC and your coin cell voltage?
Thanks!
1,311件の閲覧回数
vinothkumars
Thank you for your reply,
Vdd is 3.3volt and vbad is 3.3 volt
Vinothkumar Sekar
