TJA1021 tranceiver circuit diagram
ykp3036
Is there any error in following Lin tranceiver TJA1021 circuit diagram?
When i use the S32K14 uart-lin, test will success.
But when i use the MPC5744P, test will fail and occurs bit error.
When i connect LINTX and LINRX, test will success.
So i suspect there is some error in my TJA1021 circuit diagram.
Could any one help me to check?
guoweisun
我不清楚你是用的master 还是salve node,我给您的那个app note里面有电master 的电路也有slave的电路,有MCU TX/RX内部上拉,也有无内部上拉的推荐电路,您仔细看看会有所帮助。
ykp3036
Sorry, i don't think this can help me solve problem
ykp3036
MPC5744 has the independent LIN module, S32K14 has the LIN in UART module
guoweisun
I attached the app note which has the typical application reference circuit of TJA1020.
Hope this could help you!
If any questions please let me know!
ykp3036
guoweisun
guoweisun
你有电话吗?我可以打一个电话给你
ykp3036
ykp3036
大佬,加个微信,
yzqgymykp
