[S32V234 EVB]YOCTO building fsl-auto-bsp image, error
461 次查看
ChenHao41
I downloaded the  https://source.codeaurora.org/external/autobsps32/auto_yocto_bsp -b release/s32v_bsp23.1 package from freescale,
and tried to follow the S32V-Yocto-VisionSDK-build-tips - v2.pdf to build Yocto BSP image for s32v234evb board.
when I try to bitbake, I get the following error:
$:.../fsl-yocto-auto-bsp/build_s32v234evb $ bitbake fsl--image-auto
ERROR: Layer 'virtualization-layer' depends on layer 'networking-layer', but this layer is not enabled in your configuration
anybody can give me some suggestion? Any help would be greatly appreciated.
标记 (1)
454 次查看
Bio_TICFSL
Hello ChenHao41,
You need download all the yocto packages in you host before build the BSP, in this case you need to install networking-layer or you have to enable, but is better is you install everything yocto need:
https://docs.yoctoproject.org/1.8/yocto-project-qs/yocto-project-qs.html
