Programming the MT25QU512 using the MCUXpresso IDE for the MIMXRT117HCVM8A microcontroller
NXPer
I have a board designed that uses the MIMXRT117HCVM8A microcontroller. I cannot program the MT25QU512 QSPI flash memory because the MCUXpresso IDE is very limited in QSPI drivers. It's limited in size and QSPI device support, only having four drivers.
Is there any support out there for the MT25QU512 QSPI flash using the MCUXpresso IDE for the  MIMXRT117HCVM8A microcontroller?
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, I reviewed your information but as you mentioned the IDE only offer 4 generic drivers, I suggest there is a thread that could help you to do your driver.
How to create a new Flash driver of the MCUXPresso... - NXP Community
Pavel
