I have a chip PTN5110. The alert pin is always at a high voltage level. Inserting the device did not respond. Below is my schematic diagram , PTNT5110 's data of register and device tree.
Please give me some suggestions.Thank you.
When there is no device inserted
When device inserted
device tree
Looking at your schematic, I see you have the ALERT_N pin correctly pulled up to VDD through a 10k resistor, so there is probably some sort of SW problem.
Please refer to the AN12137 for more information about the ALERT_N interrupt pin as well as related ALERT and ALERT_EXTENDED registers.
BR, Tomas
