PCA82C251- Resistance between CANH and CANL
AikangPhil
We bought two batch PCA82C251 chip:
Old batch:82C251Y /5504/D940
New batch:82C251Y /3502/D037
We faced the CAN communication problem with the new batch(82C251Y /3502/D037),and we measured the resistance between CANH and CANL ,The R=64KΩ,It's higher than the old batch(82C251Y /5504/D940),The R of old batch =37KΩ.
So we wonder the new batch (82C251Y /3502/D037) might be the fake chip ,could you please explain this for me, thank you very much.
guoweisun
HI
Please refer to datasheet parameter-Rdiff range is from 20K to 100K,you test result for two lot within this range,no problem for this ICs.
AikangPhil
Thank you very much for your answer. but we faced the communication problem, It looks the R may influence the communicate rate ? And we used the 37KΩ ICs without any problem for the past several years, How can we buy the selected 37KΩ ICs, does the factory have methods to control it? if possbile, you can call me to discuss it ,my phone: 13794495859
Thank you very much.
guoweisun
We can't control this parameter because they are within spec.
can you share with your schematic?
AikangPhil
Thank you very much, I will share this with our engineer.
