HI team,
I wanted to know is there any way to upgrade the firmware version of NFC USB dongle. If yes please let me know. The dongle which am using is this one https://www.mikroe.com/nfc-usb-dongle
Shikamaru
Hello @Shikamaru
I would like to know why you need to update the firmware? Or what version are you in now? The software part of this product has not been updated for a long time. As you know, this product is not an end product of NXP. The manufacturer (Mikroe) may have made some updates, but NXP is unaware of it.
Kelly
Thanks @KellyLi ,
The reason to upgrade the firmware is that, wanted to do some modification in firmware like instead of detecting as HID device wanted to change it into as CDC device. And one more things , how to debug the present firmware , need to add some print statements for the sake of debug. Can you guide me here!
Shikamru
Hello @Shikamaru
Your modification requires porting the USB CDC protocol stack and modifying the corresponding application to meet your needs. At least for now, I haven't seen any updates here, but I will report your need anyway. However, PN7150 will gradually be replaced by PN7160, and the possibility of firmware update plan for PN7150 is very small. Most likely you need to do it by yourself.
kelly
