LLDP build with RT kernel
1,047件の閲覧回数
ranga_yn
Hello NXP team,
i wanted to build the LLDP for LX2160 ARDB with RT kernel enabled - let me know the steps for the same.
Thanks.
R
1,015件の閲覧回数
yipingwang
I assume that you are using lf-5.15.71 release.
1. $ bitbake virtual/kernel -c patch -f
Go to Kernel source code folder build_lx2160ardb-rev2/tmp/work/lx2160ardb_rev2-fsl-linux/linux-qoriq/5.15.71+gitAUTOINC+95448dd0dc-r0/git,
$ git checkout -b lf-5.15.71-rt-2.2.0 lf-5.15.71-rt-2.2.0
2. $ bitbake virtual/kernel -c configure
Go to Kernel build folder build_lx2160ardb-rev2/tmp/work/lx2160ardb_rev2-fsl-linux/linux-qoriq/5.15.71+gitAUTOINC+95448dd0dc-r0/build, run the following command
$ bitbake ARCH=arm64 menuconfig
Enable CONFIG_PREEMPT_RT
3. Rebuild Linux Kernel
For LLDP 6.x Linux Kernel, RT Kernel branches are not created.
