JN5189
JN5189
qianchihuang
I have a problem now, I now have a network of coordinators, routers and terminal nodes, when I want to coordinate the node to send messages, the destination network address is 0x0000 by default.
if I want to send information to the router, how to view this address?
Gavin_Jia
Hi @qianchihuang ,
Hope you are doing well!
When a device joins the network, the gateway will have the address information of the connected device.
Would you mind checking the announce related code on the gateway side? There should be a printout of the short address.
Gavin
