How to read the OTP file from a PF8200 PMIC?
etimms
I have a KITPF8200FRDMPGM programming board and I would like to know if it is possible to read the OTP file from a PF8200 PMIC using this device? I would like to verify which OTP file was used to flash the PF8200 IC's.
I have looked through the programming board user guide but this only tells me how to read individual registers and not the whole OTP, which is what I would like to do. Thank you.
